Manjaro ARM Sway Profile
#21
So I did some final round for the upcoming 20.08 release on the weekend. Theming got much improved by now:
  • /etc/sway/themes/templates/ contains config templates for various files to be updated as soon as the theme changes
  • /etc/sway/config.d/ contains sway configs (exec_always), which takes the templates, replaces some placeholders with theme specific (color) values and moves them to the corresponding $HOME/.config folder
  • still there are two theme files matcha-green (default) and matcha-blue in /etc/sway/themes that hold the configuration for Matcha-Dark-sea and Matcha-Dark-azul themes respectively; configuration of the active theme via variable in /etc/sway/definitions
Next blog post will be about creating custom themes for the Sway profile....
As usual pre-release versions of the images are on a separate OSDN: https://osdn.net/projects/manjaro-arm-sway/storage/.
If no blocking issues will be found the next release will come along with 20.08!
Thanks for all your support!
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,311 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,862 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,980 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,931 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,443 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,804 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,974 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,136 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,322 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,141 11-14-2023, 10:57 AM
Last Post: trifleneurotic
