No Wifi on new pinebook pro
I just received my new pinebook pro today. It booted up no problem. But there is no wifi? When I do ip addr in a terminal it only shows a loopback adapter no wifi adapter.
your help is appreciated.
geekyjm
It appears that some Pinebook Pros are coming from the factory with the privacy switch engaged.
See this;
https://wiki.pine64.org/index.php/Pinebo...y_Switches
Arwen Evenstar
Princess of Rivendale
My new Pinebook Pro also does not seem to be able to use Wifi; I've already tried the privacy switch and it does nothing, except it seems to turn off the bluetooth, which is working apart from the Wifi. Any ideas of why that would be? I was under the impression that both wifi and bluetooth were handled by the same AMPAK chip but perhaps I misunderstand?
Edit: It turns out the issue was largely PEBKAC. The privacy switch indicator and the privacy switch itself seem to be separate toggles; tapping META+F11 causes the privacy switch indicator to blink as if you'd toggled the Wifi without actually toggling it. One needs to hold META+F11 for three seconds before it will actually cause the privacy switch to toggle.
  Wifi no longer works christophercollins 3 477 11-21-2026, 12:25 AM
Last Post: NorrisFByrd
  Video Editing Is Possible On The PineBook Pro! ImmyChan 12 17,880 11-14-2026, 11:15 AM
  Updated Pinebook Pro? tantamount 2 2,879 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,647 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 2,118 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,839 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,310 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 11,337 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 2,321 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 9,218 08-02-2025, 08:55 PM
