SD won't boot
I'm new to the Pinebook Pro. I bought a used one a few days ago. I decided to update to Manjaro; no problem. Now I'd like to re-install using
Manjaro-ARM-kde-plasma-pbpro-20.04-emmc-installer-20.04.img
When I insert the SD and power cycle, it wouldn't boot. I thought that maybe I needed to install the original software and then try. I couldn't boot the original SD.
Any ideas?
Thanks.
When you have booted the PBP and insert the SD, can you access the SD and see the directories?
Can you check with something like GParted if the SD is showing any problems?
With an SD inserted, gparted doesn't show the SD.
(05-29-2020, 03:26 AM)jiyong Wrote: When you have booted the PBP and insert the SD, can you access the SD and see the directories?
With and SD inserted, gparted does not show the device. Strange.
Strange indeed.
Another SD is visible in GParted?
(05-29-2020, 02:18 PM)jiyong Wrote: Strange indeed.
I can't boot off SD as well. I tried 2 different 128 GB cards with different PBP images (mrfixit and armbian). I can format and also see my SD cards within Gparted. After inserting, it goes straight into the default Manjaro OS. Any tips would be appreciated.
Do you have a SD card without PBP image, or can you format it with another machine?
Boot your PBP with eMMC and see if you can access the SD card.
Just checking if your SD slot is still working.
I'm not sure if I should hop on this thread, or start my own.
I just received my brand new PBP this week.  I'm really not a fan of Manjaro.
I've been playing with Ubuntu on an SD Card.  At first, I didn't think I could get it to boot an SD Card at all, but I saw some posts talking about running the MrFixIt script, so I downloaded the newest version of the script and ran it in Manjaro, and it seemed to do some stuff.  After that, I rebooted and found that I booted into Ubuntu on my SD Card and thought that all of my problems were solved; however since then I've discovered that the machine will never COLD boot from the SD Card.   If I completely power off the machine, and power it back on, it always boots to Manjaro on the eMMC, then if I reboot from Manjaro with the SD Card inserted, it boots Ubuntu from the SD Card.
Any ideas?
(05-30-2020, 05:14 PM)ALBNC1974 Wrote: I'm not sure if I should hop on this thread, or start my own.
Any ideas?
ALBNC1974 - what MrFixit script did you use?
At first I used this one on my May 2020 PBP:
https://github.com/mrfixit2001/updates_repo/tree/v1.1
At that time, I was still able to boot into the default Manjaro without the SD card.
I then updated using uboot.img 2.0 from here:
https://github.com/mrfixit2001/updates_r...filesystem
After that, I was no longer able to boot into Manjaro or through an SD card.
Right now, I'm using an OS off of the SD card without the eMMC.
I used the 2.0 script
  3 days in, slow/stuck or no boot. lgmpbp2 34 16,865 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 10,660 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 7,965 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 2,327 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 3,260 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 2,304 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 5,575 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 1,674 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 6,993 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 3,222 12-13-2023, 08:17 PM
Last Post: trillobite
