Manjaro 20.03 did not update.
I installed Manjaro KDE onto my eMMC from the SD card using the DD method. Almost straight away I was notified that updates were available via the desktop icon, I updated and all was good. I then used my Pinebook Pro as normal, however I did not see the update icon offer any updates, so I would open the software updater and check only to be told that my system was up to date.
I saw that version 20.04 was available. I checked and found out that I was on version 20.03, so I ran the software update and it told me that my machine was up to date. I then dowloaded (via anotherPC) and reinstalled Manjaro, this time version 20.04 and again was informed via the update icon that there were updates available. I got an error telling me that one of the updates could not dowload as a file already existed, solved by renaming the file and running the update again.
So I am now running Manjaro KDE 20.04 but my question is how come 20.03 did not update?  Huh
Thanks in advance Smile
(05-14-2020, 10:31 AM)MrDitchy Wrote: I installed Manjaro KDE onto my eMMC from the SD card using the DD method. Almost straight away I was notified that updates were available via the desktop icon, I updated and all was good. I then used my Pinebook Pro as normal, however I did not see the update icon offer any updates, so I would open the software updater and check only to be told that my system was up to date.
Not sure if your problem is the same as mine. But I also had trouble updating my pinebook pro -- also using Manjaro KDE.
For me it was two things.
1. Apparently they moved the mirrors and that is why from the update icon I only got "there are no updates available" while `pacman` told me that it could not reach anything. (source)
2. After 1. was fixed, I still had some trouble updating. It told me something about an nss file already existing. That had something to do with arch and I followed this
[url=https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/][/url]
Upgrade to 20.04 is not recommended.
You need a fresh install to get all the new features with this version.
Make a backup of your data and reflash your emmc.
thanks for the info. I think I ended up doing this way anyway, because I then switched from kde to xfce.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 1 97 08-05-2025, 06:40 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 1,256 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 1,603 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 1,548 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 1,599 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 3,343 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 1,541 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 4,626 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 5,336 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 1,540 12-07-2023, 03:11 PM
