Problem updating Manjaro
I'm trying to update my Manjaro install and I'm hitting errors trying to connect to "manjaro-arm.ericlay.online".  Any ideas?
Thanks.
I had a similar problem today trying to update a manjaro image I hadn't used in a few weeks. The 2020.02 release notes suggest manually updating the mirror list. After following those instructions I was able to download all the new packages, but the kernel package fails its signature check, so I still haven't been able to update.
I was able to solve the kernel signing issue by running
sudo pacman -Sy manjaro-arm-keyring
(03-19-2020, 02:31 PM)bceverly Wrote: Hi,
Thanks.
I think you're using older version of Manjaro image and this error is caused by change in our mirror repo structure.
Old mirrors are no longer active.
You will have to install the latest mirrors manually using the following command.
sudo pacman -U https://ftp-osl.osuosl.org/pub/manjaro-arm/repo/stable/core/aarch64/pacman-mirrorlist-20200225-1-any.pkg.tar.xz
sudo pacman-mirrors -b stable
sudo pacman-mirrors -g
sudo pacman -Syyuu
I hope this works and if it doesn't work then you need to flash the latest image which is 20.02.1 from official manjaro page.
Try the above and let me know.
Manjaro ARM Team.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,312 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,862 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,982 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,935 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,445 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,808 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,979 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,141 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,324 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,143 11-14-2023, 10:57 AM
Last Post: trifleneurotic
