Kodi on Manjaro
(03-12-2020, 01:15 AM)brent.thierens Wrote: How can I check if this uses sw or hw rendering?
Could it be that we need to do this to get HW acceleration working: https://forum.manjaro.org/t/manjaro-arm-.../112647/24
HW rendering is working on Kodi app UI but video playback is running on software acc.
If you check in system information, you see that its using Panfrost and Open GL for Rendering.  While when you play any video and press "o" and it will show you the playback information there it will show you (SW ACC).
As ARM Devices have Different Drivers for GPU and VPU. Currently panfrost is the GPU which is achieved from open source project, Soon in 5.7 we will have some support for VPU. So we will have to wait for it.
Manjaro ARM Team.
(03-11-2020, 08:06 AM)spikerguy Wrote:
(03-10-2020, 07:42 AM)brent.thierens Wrote: I did build it on the PBP itself. I'm on KDE with Xorg, Compositing enabled. For me, everything was running smooth actually...
I'll try the package from the repo and see if there are any differences, if so, we can investigate what the differences where Smile
I build it on my Vim3 with kde and gles.
Kodi package
It is uploaded to the Manjaro Repo. This kodi build needs GLES support, it only plays video with software decoding. There was no screen tearing or lag. Kodi UI works smooth as it is hw acc.
How to install
For users on Stable branch
Step 1:
sudo pacman-mirrors -b unstable
[size=undefined]
Step 2: [/size]
sudo pacman -Syy kodi
Users on unstable branch can skip Step 1.
Nice work brent. Thanks.
Did you create package under https://gitlab.manjaro.org/manjaro-arm/packages ? I would like to clone it (it is easier to update PKGBUILD and files over git then collecting files over forum).
Kodi package
How to install
Step 1:
[size=undefined]
Step 2: [/size]
I will upload it tonight. I have make PKGBUILD's pending to upload.
You should be to able to see it in community brand of our gitlab repo.
Manjaro ARM Team.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,301 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,846 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,964 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,919 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,425 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,797 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,945 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,107 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,309 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,131 11-14-2023, 10:57 AM
Last Post: trifleneurotic
