Akregator in Manjaro
Overall Manjaro has worked fairly well. I was able to get printing working and sort out getting most of the KDE-PIM packages working. It seems to me those issues should be sorted out and working out of the box.
I have not been able to get Akregator working. It freezes up when I go to fetch feeds. And if I am using it inside Kontact, it freezes up Kontact as well. I have searched the web in general for solutions and used the Arch Wiki as well without finding anything relating to this problem.
If anyone has any ideas on a solution to get Akregator working in Manjaro for the Pinebook Pro I would appreciate some assistance.
thank you
bill
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 3,937 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,423 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,413 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,786 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,265 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,574 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,520 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 10,695 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,185 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 4,945 11-14-2023, 10:57 AM
Last Post: trifleneurotic
