Chromium on Pinebook Pro blocked by Google: "This browser or app may not be secure"
Whatever I do, I can not login to my Google Account with Chromium on Pinebook Pro.
"Less secure apps" is on.
Firefox works so far.
(03-01-2020, 02:28 PM)lowry Wrote: Whatever I do, I can not login with chromium on Pinebook Pro.
I don't understand what you are doing.
Are you accessing a website that blocks you when you use Chromium?
Indeed. I can't login to Google Account with Chromium on Pinebook Pro.
Ok, do you start Chromium from the panel (at the bottom), or through the menu?
Chromium starting from the panel spoofs the user-agent.
You can try to alter it to spoof a newer version (right click > properties).
Did you try to update Chromium with the package manager?
If all else fails, you can try to install a newer version with snap.
Jamie Phillips has a video where he explains how to do it.
https://www.youtube.com/watch?v=5STcNkylTAg
I had the same happen, but it seemed it happened when I started Chromium before the network connection was established. When I quit Chromium, then reconnect the WiFi and restart Chromium it worked.
  Video Editing Is Possible On The PineBook Pro! ImmyChan 12 17,574 11-10-2026, 09:48 PM
Last Post: noahclark
  Updated Pinebook Pro? tantamount 2 2,698 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,477 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 2,000 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,682 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,173 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 11,140 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 2,212 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 9,099 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,438 06-28-2025, 01:25 AM
Last Post: Www
