Chromium on Pinebook Pro blocked by Google: "This browser or app may not be secure"
Whatever I do, I can not login to my Google Account with Chromium on Pinebook Pro.
"Less secure apps" is on.
Firefox works so far.
(03-01-2020, 02:28 PM)lowry Wrote: Whatever I do, I can not login with chromium on Pinebook Pro.
I don't understand what you are doing.
Are you accessing a website that blocks you when you use Chromium?
Indeed. I can't login to Google Account with Chromium on Pinebook Pro.
Ok, do you start Chromium from the panel (at the bottom), or through the menu?
Chromium starting from the panel spoofs the user-agent.
You can try to alter it to spoof a newer version (right click > properties).
Did you try to update Chromium with the package manager?
If all else fails, you can try to install a newer version with snap.
Jamie Phillips has a video where he explains how to do it.
https://www.youtube.com/watch?v=5STcNkylTAg
I had the same happen, but it seemed it happened when I started Chromium before the network connection was established. When I quit Chromium, then reconnect the WiFi and restart Chromium it worked.
  Pinebook Pro for sale rfm83 0 338 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 4,824 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 6,842 08-02-2025, 08:55 PM
  Pinebook problem meghancordo 1 4,148 07-24-2025, 07:28 AM
Last Post: mikehenson
Question Printing and scanning documents with pinebook? Www 0 3,710 06-28-2025, 01:25 AM
Last Post: Www
  Pinebook Pro in EU for Sale - €90 jan_vdk 4 7,086 06-19-2025, 02:14 AM
Last Post: shelfaberrant
  Use SD to install new OS over pinebook debian Rudy558 10 23,547 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 4,682 02-05-2025, 03:56 AM
Last Post: waylonwesley
  Pinebook Next !spekulation! Surehand53 2 5,592 01-23-2025, 11:49 AM
Last Post: Surehand53
  Pinebook Pro wants a PIN for my bluetooth mouse ColoBill 1 4,194 01-19-2025, 04:38 PM
Last Post: ColoBill
