Chromium on Pinebook Pro blocked by Google: "This browser or app may not be secure"
Whatever I do, I can not login to my Google Account with Chromium on Pinebook Pro.
"Less secure apps" is on.
Firefox works so far.
(03-01-2020, 02:28 PM)lowry Wrote: Whatever I do, I can not login with chromium on Pinebook Pro.
I don't understand what you are doing.
Are you accessing a website that blocks you when you use Chromium?
Indeed. I can't login to Google Account with Chromium on Pinebook Pro.
Ok, do you start Chromium from the panel (at the bottom), or through the menu?
Chromium starting from the panel spoofs the user-agent.
You can try to alter it to spoof a newer version (right click > properties).
Did you try to update Chromium with the package manager?
If all else fails, you can try to install a newer version with snap.
Jamie Phillips has a video where he explains how to do it.
https://www.youtube.com/watch?v=5STcNkylTAg
I had the same happen, but it seemed it happened when I started Chromium before the network connection was established. When I quit Chromium, then reconnect the WiFi and restart Chromium it worked.
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 102 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 893 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 4,739 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 7,978 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 691 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 5,291 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 7,261 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 3,998 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 25,720 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 5,066 02-05-2025, 03:56 AM
Last Post: waylonwesley
