An unofficial Debian Installer for Pinebook Pro
(02-13-2020, 04:51 PM)wasgurd Wrote: Has somebody tried linux-image-5.5.0-rc5-arm64 from experimental?
I haven't but, to be honest, I would expect the display not to work! There is a patch needed for the display that didn't land until v5.6-rc1 .
I have currently got a local v5.5 based build (which does include the display patch and many of the other things @tsys has been working on). I found and fixed an integration bug related to the maxcpus=4 hack .
I've not done much with it but it appears to be working (although panfrost feels less stable than it did with the v5.4 family but I could be imagining that). However I am seeing a pile of warnings about missing modules as the system boots up. I think it is simply that the kernel is less modular and most of the warning reflect modules that are not built in but I'd like to double check that before pushing it to OBS.
(02-13-2020, 10:10 AM)tpm Wrote:
(02-13-2020, 09:18 AM)maya.b Wrote: You don't happen to have a linux-headers package for the 5.4.2.2-pinebookpro-arm64 kernel by any chance?
There's a linux-headers-5.4.2-2-pinebookpro-arm64 package.
huh - how'd I miss that ...
Thanks!
I like it but I'd like to see a couple more menu options.  Partition table type - I don't like GPT, rather have MBR.  Or if it has to be GPT have the option of a real swap partition (user specifies size).  Gparted doesn't successfully resize a GPT partition the only time I tried it.
And I'd probably rather have Buster than Bullseye, so an option to choose would be good.
I'm curious about the files in /lib/firmware --
two questions:
1) Where do they come from? - in case I want to download them again/check for new versions.
2) why aren't they package-ized, so I can poke at them with dpkg? Should/shouldn't they be? (Has this changed since a few weeks ago when I used the installer?)
you can read the installer and the git submodule configs. they are blobs pulled from other git repos.
(02-14-2020, 07:18 PM)bsammon Wrote: I'm curious about the files in /lib/firmware --
two questions:
Yes, they should be packaged... however ideally that should happen by the firmwares being pushed into the upstream linux-firmware repository (which may need help from Rockchip to sort of out the legal details). From they will flow into the Debian packages and eventually the existing not-packaged firmwares will be overwritten.
I don't really want to create (or maintain) a package that reduces the pressure to get it fixed properly.
I may have done something wrong, but using the debian installer default kernel, or with an updated (5.5 thanks to @tsys ) one, I can't have sound on the speakers and jack output.
I tried to use the asound.state from @danielt 's repo but it doesn't change anything.
Is there anybody with this kind of problem ?
On the default @Mrfixit2001 debian it work's
use the asound.state from manjaro, it is updated. i've edited the installer to do so, see my patch in my sig.
for ...post install changes:
pull pinebookpro-post-install from manjaro
place asound.state in /var/lib/alsa
sudo alsactl nrestore
reboot (optional...)
configure in pavucontrol
if that doesn't work, alsamixer (f6 for default and es8316)
should work.
while your at it read the PKGBUILD from manjaro and consider the additional changes they have tested.
two questions:
just pull the second firmware repo from manjaro and dump into /lib/firmware/brcm/ like the other. see my patch for a bunch of changes  such as this.
(02-18-2020, 11:31 AM)xmixahlx Wrote: use the asound.state from manjaro, it is updated. i've edited the installer to do so, see my patch in my sig.
should work.
It works great !  Thanks !
My next and last problem is the wifi 5ghz stability, do any of you have this kind of problem ? The speed is stuck to 6mbit/s, on the default debian it was working pretty fast. I think it's related to the firmware but I don't understand anything to the broadcom blob firmware
Thank you for sharing this @danielt . I'm new to this but would like to try this out. What would be the basic steps to get this working? Say I want to run this from sdcard, I download the script while booted from stock Debian and run it from terminal, just make sure I select the right device to install to? I saw a few pages back that the installer switches the naming of the devices where sdcard is normally mmcblk0 and pb64 is mmcblk1 it is opposite so I need to pick mmcblk1?
Edit: Disregard, I found the instructions on github. If I have issues I'll try to work it out then post here.
  Window Maker Live for Pinebook Pro vajak 8 2,977 01-22-2026, 08:00 PM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,735 08-09-2025, 06:53 AM
Last Post: Sb2024
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 15,148 06-26-2025, 09:20 PM
Last Post: reukiodo
  Boot Order in Pinebook Pro food 11 12,703 03-28-2025, 10:08 AM
Last Post: DrYak
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,535 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 105,887 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,627 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 10,083 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 13,638 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,559 12-13-2023, 07:22 PM
Last Post: trillobite
