An unofficial Debian Installer for Pinebook Pro
interesting...
I refer to: https://wiki.debian.org/SourcesList for any of these types of questions.
Really cool to see people making interesting mods for the installer. As far as I am concerned that's what it is there for (i.e. why I didn't just release an SD card image).
To be honest I was very on-the-fence about buster verus bullseye but eventually opted for bullseye to allow people to experiment with panfrost. However if I want to workaround something that makes panfrost unstable I tend to add modprobe.blacklist=panfrost to the kernel command line. I'd also note that software acceleration isn't nearly as bad as you might think... when I first got it working I didn't get the panfrost config right and it fell back to s/ware... it took me a week to notice ;-) ,
Anyhow as ever pull requests for DISTRO=buster/bullseye/sid support are both welcome and encouraged.
(01-30-2020, 07:40 AM)danielt Wrote: Really cool to see people making interesting mods for the installer. As far as I am concerned that's what it is there for (i.e. why I didn't just release an SD card image).
With regards hw acceleration, I believe it would be nice a guide/howto on how to check if hardware acceleration is enabled in Debian and how to enable it if it is not.
Also I've seen a tendency on compiling mesa from git which makes me worry about the updates and such. Wouldn't be better to use sid/experimental packages instead? Or even better, create a debian package with the mesa git repo?
I can't seem to find the thread around here I've seen about double and triple finger taps not detecting reliably, with someone recommending to increase the distance between the fingers. Well, looks like it doesn't have anything to do with the finger distance, but instead with the default settings for tap detection max time - looks like by default it is configured to 180ms, and increasing it to 250ms made double and triple finger tap detection pretty much almost 100% reliable.
P.S.: has anybody braved the linux-image-5.5.0-rc5-arm64 kernel from Debian Experimental?
(01-30-2020, 08:00 AM)e-minguez Wrote: With regards hw acceleration, I believe it would be nice a guide/howto on how to check if hardware acceleration is enabled in Debian and how to enable it if it is not.
Checking which renderer is in use is as simple as: glxinfo | grep 'OpenGL renderer' (this works even when you are running under wayland since the embedded X server for legacy apps will still pick up the right strings).
there are now mesa-git packages in debian experimental, which you could install via apt pinning. however if you aren't on unstable already this will probably break more things then fix.
security issues can be resolved by... rerunning the mesa-git script. with ccache this takes just a few minutes...
usage will just boil down to how comfortable you are with git-based /usr/local installs.
I will post kernel install scripts shortly. 5.5-rc7+panfrost-fixes is working nicely!
no kernel in debian proper will work correctly until tsys' patches are merged upstream.
This continues to be a rewarding and interesting thread. @danielt thanks for your helpful and enlightened senior participation. It's just the right balance of enablement and cautions that go a long way, in fostering a community such as this.
— Jeremiah Cornelius
've observed some issues with my FDE system when there are times that the boot hangs waiting for the device (see attached). To fix it I just cycle power it off and on a few times until it works. Am I the only one? It can be a hardware issue?
https://pasteboard.co/ISow5Qc.jpg
Thanks very much, Danielt for your installer, support of the community and sharing your insights and experiences.  Its great to have Debian options and to keep moving the PBP project along .  Much appreciated!
Memory filesystem
If I recall correctly, Manjaro sets up several memory filesystems. Any thoughts on introducing memory filesystems for /tmp and friends on our Debian builds?
The plus: Less flash wear.
The minus: on a memory constrained system such as the Pinebook Pro (and in particular in combination with 64bit binaries) this might result in more paging.
Note: When I was running Manjaro for some time, emacs's cscope mode was requesting more space in /tmp than what was configured. So, with a conservative /tmp size, we may run into problems from time to time.
  Boot Order in Pinebook Pro food 12 17,884 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,960 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,988 08-09-2025, 06:53 AM
Last Post: Sb2024
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,248 06-26-2025, 09:20 PM
Last Post: reukiodo
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,312 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 120,307 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,575 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,159 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 17,114 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,103 12-13-2023, 07:22 PM
Last Post: trillobite
Users browsing this thread: 9 Guest(s)
