PyQT5 Manjaro
Hi All, I've been trying to run electrum wallet from python source on the Manjaro image.  Everything fails looking for pyQt5.
This is installed via pacman so not sure why It's not working...
Everything I find online seems to be a dead end so wondered if anyone had any ideas how to get it working?
Not sure if this helps, but PyQt5 requires a full Qt install to work properly.
(01-25-2020, 12:27 AM)metcalsr Wrote: Not sure if this helps, but PyQt5 requires a full Qt install to work properly.
All fixedSmile
Long story short, I just learned never to use pip to install anything.
I also found that when I added additional mirrors to pacman everything seems to be installing properly so might be a combination of the two!
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,850 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,305 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,810 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,271 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,644 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 2,922 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,182 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,371 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 2,706 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 4,270 11-14-2023, 10:57 AM
Last Post: trifleneurotic
