Pardon my ignorance, but how do I install Manjaro XFCE (on SD card)? Do I just downlad straight from the downloads page on the Manjaro website (https://manjaro.org/download/) or is there a specific build for the pinebook pro? Is this where I go https://forum.manjaro.org/t/manjaro-arm-...pro/112647? When I click on the link for to download preview 4 with xfce here, I get 'page not found here https://osdn.net/projects/manjaro-arm/st.../preview4/.
I also feel a little lost
If I understand well, to build a bootable SDcard, I need to have a machine already running Manjaro and install the tools?
"The Manjaro project offers a mainline kernel with patches and modules to support PBPro hardware in two flavors. Both provide DD images and installer images (DD to SD card which will then install to eMMC when booted)."
https://wiki.pine64.org/index.php/Pinebo...anjaro_ARM
I've never been able to get boot with these images.
Is it normal after creating them with dd not to have a boot partition?
I used this command : sudo dd if=Manjaro-ARM-xfce-pbpro-19.12.1.img of=/dev/mmcblk0 bs=4k status=progress
Maybe try Etcher or the PINE64 Installer?
> bs=4k !!!!!!!
DON'T DO THAT
Hard on card, if nothing else, bloody slow
bs=1M is far better
(01-11-2020, 01:55 PM)zaius Wrote: "The Manjaro project offers a mainline kernel with patches and modules to support PBPro hardware in two flavors. Both provide DD images and installer images (DD to SD card which will then install to eMMC when booted)."
There’s also a Gnome Shell test build:
https://forum.manjaro.org/t/pinebook-pro...oad/113333
Bingo! I see it now. I'll get down to that later now that I know where to go (laptop is not with me right now). Thank you for pointing me in the right direction. The Wikipedia page is good. Smile
(01-11-2020, 01:48 PM)agD0i7rY Wrote: I also feel a little lost
I think I can answer that. Just use the operating system you already have on your pinebook pro to download the manjaro iso file. Download it straight to the SD card. Then make a bootable file out of it using the default software already on the computer (I think I saw 'installer' mentioned in a nearby post here, or else with 'dd etcher' (I hope I've got the name right there). Or else indeed do this from another computer with whatever operating system and tools that happen to be on it. I'm going to go at it myself straight from Debian mate on the pine this evening and I'll let u know how I get on. I think u might have to format the SD card first though even if it's new. I think I see the preferred format in a nearby post here. M1 I think it says.
I'm wrong about the meaning of 'dd'. It seems that refers to the option you choose if you want it to replace the existing o.s. on your emmc drive.
(01-11-2020, 02:23 PM)zaius Wrote: Maybe try Etcher or the PINE64 Installer?
I tried Etcher from another computer and it was the same.
I tried with several SD Cards, including one that booted with the official Debian.
I'll try to check with PINE64 installer.
(01-11-2020, 07:58 PM)wdt Wrote: > bs=4k    !!!!!!!
DON'T DO THAT
bs=1M  is far better
I had kept this option for a backup and resize of an SD.
Does it damage the card that much?
dd is the command to write to SD or emmc.
For the moment I would like to do it with SD to test Manjaro.
I had a Manjaro on my old computer that died...
I'm willing to get a description of your actions to set all this up. Smile
Thank you all!
(01-11-2020, 12:07 PM)leibide Wrote: Pardon my ignorance, but how do I install Manjaro XFCE (on SD card)? Do I just downlad straight from the downloads page on the Manjaro website (https://manjaro.org/download/) or is there a specific build for the pinebook pro? Is this where I go https://forum.manjaro.org/t/manjaro-arm-...pro/112647? When I click on the link for to download preview 4 with xfce here, I get 'page not found here https://osdn.net/projects/manjaro-arm/st.../preview4/.
That's an outdated image. Current release downloads can be found here: https://forum.manjaro.org/t/manjaro-arm-...sed/114406
Did you get that preview image from the wiki? We need to update it if so.
To install for booting off SD, download a PBP image without 'emmc-installer- in the filename to your computer. Use dd or an app to burn the image to SD (i.e. Etcher.) After that you can insert the SD into the PBP and boot from it.
  Window Maker Live for Pinebook Pro vajak 1 293 12-10-2025, 05:19 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,127 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,448 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Boot Order in Pinebook Pro food 11 10,669 03-28-2025, 10:08 AM
Last Post: DrYak
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 3,842 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,312 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,659 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 93,110 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,100 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 8,801 03-31-2024, 10:11 AM
Last Post: u974615
