Hibernate Manjaro -> NetworkManager doesn't start anymore
today I pushed the button to hibernate the system but it didn' t wake up again. So I pushed the power button to restart the notebook.
Now sytemd can't start NetworkManager.service. There is a core-dump.
Is ist possible to make NetworkManager work again?
[~]> systemctl status NetworkManager.service
● NetworkManager.service - Network Manager
    Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service>
   Drop-In: /usr/lib/systemd/system/NetworkManager.service.d
            └─NetworkManager-ovs.conf
    Active: failed (Result: core-dump) since Sat 2020-01-11 18:15:>
      Docs: man:NetworkManager(8)
   Process: 835 ExecStart=/usr/bin/NetworkManager --no-daemon (cod>
  Main PID: 835 (code=dumped, signal=ILL)
Jän 11 18:15:05 b00k systemd[1]: NetworkManager.service: Scheduled >
Jän 11 18:15:05 b00k systemd[1]: Stopped Network Manager.
Jän 11 18:15:05 b00k systemd[1]: NetworkManager.service: Start requ>
Jän 11 18:15:05 b00k systemd[1]: NetworkManager.service: Failed wit>
Jän 11 18:15:05 b00k systemd[1]: Failed to start Network Manager.
[~]> systemd-analyze critical-chain
The time when unit became active or started is printed after the "@>
The time the unit took to start is printed after the "+" character.
graphical.target @3min 32.222s
└─multi-user.target @3min 32.221s
 └─smb.service @3min 31.895s +324ms
   └─network-online.target @2min 1.625s
     └─network.target @2.906s
       └─NetworkManager.service @6.023s +352ms
         └─dbus.service @2.598s
           └─basic.target @2.588s
             └─sockets.target @2.588s
               └─dbus.socket @2.588s
                 └─sysinit.target @2.586s
                   └─systemd-timesyncd.service @2.222s +363ms
                     └─systemd-tmpfiles-setup.service @2.165s +51ms
                       └─local-fs.target @2.156s
                         └─run-user-1000-gvfs.mount @26.539s
                           └─run-user-1000.mount @22.150s
                             └─local-fs-pre.target @2.156s
                               └─lvm2-monitor.service @637ms +1.14>
                                 └─lvm2-lvmetad.service @717ms
                                   └─systemd-journald.socket @606ms
                                     └─system.slice @328ms
                                       └─-.slice @328ms
[~]> systemd-analyze blame
  2min 57ms systemd-networkd-wait-online.service
1min 30.246s nmb.service
    30.062s NetworkManager-wait-online.service
     3.036s bootsplash-hide-when-booted.service
     1.143s lvm2-monitor.service
      898ms dev-mmcblk2p1.device
      779ms systemd-logind.service
      618ms systemd-random-seed.service
      441ms systemd-udevd.service
      389ms tlp.service
      363ms systemd-timesyncd.service
      353ms systemd-networkd.service
      352ms NetworkManager.service
      324ms smb.service
      297ms systemd-journald.service
      240ms user@1000.service
      239ms polkit.service
      184ms systemd-udev-trigger.service
      138ms systemd-journal-flush.service
       51ms systemd-tmpfiles-setup.service
       39ms dev-hugepages.mount
       39ms systemd-tmpfiles-setup-dev.service
       35ms dev-mqueue.mount
       34ms systemd-modules-load.service
       33ms systemd-remount-fs.service
       32ms sys-kernel-debug.mount
       30ms systemd-sysctl.service
       30ms systemd-rfkill.service
       30ms tmp.mount
       29ms systemd-backlight@backlight:edp-backlight.service
       28ms user-runtime-dir@1000.service
       27ms sys-fs-fuse-connections.mount
       27ms systemd-update-utmp.service
       27ms kmod-static-nodes.service
       26ms systemd-user-sessions.service
Jän 11 18:15:05 b00k systemd[1]: NetworkManager-wait-online.service: Job NetworkManager-wait-online.service/start failed with result 'dependency'.
Jän 11 18:15:05 b00k systemd[1]: Dependency failed for Network Manager Wait Online.
Jän 11 18:15:05 b00k systemd[1]: NetworkManager.service: Failed with result 'core-dump'.
Jän 11 18:15:05 b00k systemd[1]: NetworkManager.service: Start request repeated too quickly.
Jän 11 18:15:05 b00k systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 5.
Jän 11 18:15:04 b00k systemd[1]: systemd-coredump@4-838-0.service: Succeeded.
Jän 11 18:15:04 b00k systemd-coredump[839]: Process 835 (NetworkManager) of user 0 dumped core.
                                            Stack trace of thread 835:
                                            #0  0x0000aaaae4aa8120 n/a (NetworkManager + 0x64120)
                                            #1  0x0000ffffa21674bc g_type_class_ref (libgobject-2.0.so.0 + 0x3d4bc)
                                            #2  0x0000ffffa219e000 n/a (libgobject-2.0.so.0 + 0x74000)
Jän 11 18:15:04 b00k systemd[1]: NetworkManager.service: Failed with result 'core-dump'.
Jän 11 18:15:04 b00k systemd[1]: NetworkManager.service: Main process exited, code=dumped, status=4/ILL
Jän 11 18:15:04 b00k systemd[1]: Started Process Core Dump (PID 838/UID 0).
Jän 11 18:15:04 b00k systemd[1]: Started Network Manager.
Jän 11 18:15:04 b00k NetworkManager[835]: <info>  [1578762904.4775] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Jän 11 18:15:04 b00k NetworkManager[835]: <info>  [1578762904.4726] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf) (etc: dhcp-client.conf)
Jän 11 18:15:04 b00k NetworkManager[835]: <info>  [1578762904.4725] NetworkManager (version 1.22.4-1) is starting... (after a restart)
Jän 11 18:15:04 b00k systemd[1]: Started Hide bootsplash after starting the system.
Jän 11 18:15:04 b00k systemd[1]: bootsplash-hide-when-booted.service: Succeeded.
Jän 11 18:15:04 b00k systemd[1]: Starting Network Manager...
Jän 11 18:15:04 b00k systemd[1]: Stopped Network Manager.
Jän 11 18:15:04 b00k systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 4.
Jän 11 18:15:04 b00k systemd[1]: systemd-coredump@3-828-0.service: Succeeded.
Jän 11 18:15:04 b00k systemd-coredump[829]: Process 825 (NetworkManager) of user 0 dumped core.
                                            Stack trace of thread 825:
                                            #0  0x0000aaaab078a120 n/a (NetworkManager + 0x64120)
                                            #1  0x0000ffffbdd794bc g_type_class_ref (libgobject-2.0.so.0 + 0x3d4bc)
                                            #2  0x0000ffffbddb0000 n/a (libgobject-2.0.so.0 + 0x74000)
Jän 11 18:15:03 b00k systemd[1]: Started Process Core Dump (PID 828/UID 0).
Jän 11 18:15:03 b00k NetworkManager[825]: <info>  [1578762903.8540] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Jän 11 18:15:03 b00k systemd[1]: Started Network Manager.
Jän 11 18:15:03 b00k NetworkManager[825]: <info>  [1578762903.8492] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf) (etc: dhcp-client.conf)
Jän 11 18:15:03 b00k NetworkManager[825]: <info>  [1578762903.8490] NetworkManager (version 1.22.4-1) is starting... (after a restart)
Jän 11 18:15:03 b00k systemd[1]: Starting Network Manager...
Jän 11 18:15:03 b00k systemd[1]: Stopped Network Manager.
Jän 11 18:15:03 b00k systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 3.
Jän 11 18:15:03 b00k systemd[1]: systemd-coredump@2-819-0.service: Succeeded.
Jän 11 18:15:03 b00k systemd-coredump[820]: Process 816 (NetworkManager) of user 0 dumped core.
                                            Stack trace of thread 816:
                                            #0  0x0000aaaab3dbf120 n/a (NetworkManager + 0x64120)
                                            #1  0x0000ffffb61844bc g_type_class_ref (libgobject-2.0.so.0 + 0x3d4bc)
                                            #2  0x0000ffffb61bb000 n/a (libgobject-2.0.so.0 + 0x74000)
Jän 11 18:15:03 b00k systemd[1]: NetworkManager.service: Failed with result 'core-dump'.
Jän 11 18:15:03 b00k systemd[1]: NetworkManager.service: Main process exited, code=dumped, status=4/ILL
Jän 11 18:15:03 b00k systemd[1]: Started Process Core Dump (PID 819/UID 0).
Jän 11 18:15:03 b00k NetworkManager[816]: <info>  [1578762903.0382] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Jän 11 18:15:03 b00k NetworkManager[816]: <info>  [1578762903.0315] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf) (etc: dhcp-client.conf)
Jän 11 18:15:03 b00k NetworkManager[816]: <info>  [1578762903.0313] NetworkManager (version 1.22.4-1) is starting... (after a restart)
Jän 11 18:15:02 b00k systemd[1]: Starting Network Manager...
Jän 11 18:15:02 b00k systemd-logind[778]: Watching system buttons on /dev/input/event3 (HAILUCK CO.,LTD USB KEYBOARD System Control)
Jän 11 18:15:02 b00k systemd[1]: Stopped Network Manager.
Jän 11 18:15:02 b00k systemd[1]: NetworkManager.service: Scheduled restart job, restart counter is at 2.
Jän 11 18:15:02 b00k systemd-udevd[477]: event1: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[477]: event1: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[477]: event1: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[472]: event5: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[472]: event5: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[472]: event5: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jän 11 18:15:02 b00k systemd[1]: systemd-coredump@1-799-0.service: Succeeded.
Jän 11 18:15:02 b00k systemd-udevd[467]: event3: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[467]: event3: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[467]: event3: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jän 11 18:15:02 b00k systemd-coredump[801]: Process 796 (NetworkManager) of user 0 dumped core.
                                            Stack trace of thread 796:
                                            #0  0x0000aaaadbd66120 n/a (NetworkManager + 0x64120)
                                            #1  0x0000ffffa0e654bc g_type_class_ref (libgobject-2.0.so.0 + 0x3d4bc)
                                            #2  0x0000ffffa0e9c000 n/a (libgobject-2.0.so.0 + 0x74000)
Jän 11 18:15:02 b00k systemd-udevd[473]: event4: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[473]: event4: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Jän 11 18:15:02 b00k systemd-udevd[473]: event4: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Jän 11 18:15:02 b00k systemd[1]: NetworkManager.service: Failed with result 'core-dump'.
Jän 11 18:15:02 b00k systemd[1]: NetworkManager.service: Main process exited, code=dumped, status=4/ILL
Jän 11 18:15:02 b00k systemd-udevd[464]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jän 11 18:15:02 b00k systemd-udevd[464]: Using default interface naming scheme 'v243'.
Was this install updated in the last few days, or fresh?
If you had it going before and updated it recently (there was a problem with a NetworkManager update recently,) you could try getting into tty2 and using downgrade networkmanager and selecting 1.22.2-1
Resuming from sleep is a known issue with mainline kernel. Best to avoid putting the PBP to sleep on a mainline image for the time being. I'm sure it'll be well known once it's resolved. I imagine many of us will be quite excited about it.
(01-11-2020, 12:25 PM)tophneal Wrote: Was this install updated in the last few days, or fresh?
I updated the system yesterday, about 24 hours ago. Now I have tried to bring up wlan0 again but nothing helps so far.
I thought maybe I can bring sleepmode to work somehow. ;D
Run 'downgrade networkmanager' and go back to the previous version. you should get wlan0 back.
If you figure out getting the PBP to wake from sleep, don't forget to share it with us!
(01-11-2020, 12:38 PM)tophneal Wrote: Run 'downgrade networkmanager' and go back to the previous version. you should get wlan0 back.
thank you! I would share it. Do you know a way to downgrade a package without having "downgrade" installed?
Did you remove downgrade? When this happened to me, it was already installed.
I can't recall exactly how but I remember finding the method used for downgrading with pamac, but if I find it I'll post it.
(01-11-2020, 12:55 PM)tophneal Wrote: Did you remove downgrade? When this happened to me, it was already installed.
Maybe I did it accidently if it was there because I deinstalled the xfce and its dependencies and a lot of other packages during switching to i3w. Thank you, I will search in the pamac-manpage.
The package "downgrade" wasn't installed per default, I didn't remove it. I searched the history. I can' t find a option in pamac to downgrade. I think maybe it is possible to write the package on an Usb-stick and install it with a command from there?
@tophneal
Thank you for helping!
I managed to get it downgraded.
I found the old Version in /var/cache/pacman/pkg/
then
pamac install networkmanager-1.22.2-1-aarch64.pkg.tar.xz
simple did it. Big Grin
Great! Now that your back on your wifi, don't forget to reinstall downgrade. Makes this kinda thing a lot easier! Wink
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,351 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,945 03-15-2025, 01:47 AM
Last Post: frank_philip
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 16,944 03-10-2025, 01:55 PM
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,031 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,950 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,470 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,833 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,025 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,198 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,346 12-07-2023, 03:11 PM
