Best Pinebook Pro power supply choice for Argentina
Hi.
I'm about to order a Pinebook Pro but still not sure about the power supply option, which is EU or US formats. My country is Argentina. We use 220v. As for the plug, I guess I'll need an adapter anyway: it's the type used in Australia.
Does it make any difference to choose one or the other?
Thank you very much.
M.
Pd.  I'm new to the forum. Sorry if this is not the best place to post it, or if there's already a thread for this topic. I couldn't find useful information after a search.
(12-07-2019, 11:39 AM)LaCaradeculito Wrote: Hi.
M.
There is no electrical difference between the two power supplies it copes with any mains voltage - the only difference is mechanical with the plug adapter plate.
US is two flat prongs, Euro is two thin round pins. The adapter plate simply clips onto the body of the power module.
In the Pine store there is an "international" version which comes with a selection of country adapter plates but it is not the version provided free with the Pinebook.
Check the Pine store - if the international version includes a correct plug for your mains sockets you can ask the Pine store if they will supply you with just a single country adapter plate you need so you can use that instead of the one supplied. (a dollar or so? plus postage)
M.
Hello, I'm from Argentina too! I bought the Pinebook pro with the adapter for Europe, and it goes perfect in the plugs here. It's the one with two round legs.
Saludos !!!
I have found that a proper PD USBC supply and charge via USBC port, using a decent cable (not a cheap, lightweight cable from Aliexpress) is a better option for charging.  You can also get USBC hubs with HDMI that also allows charging at the same time.
Note it has to be a USB C PD - "Power Draw" supply, not a normal supply, not even a Raspberry Pi 4 USBC charger.
Hi, thank you all very much for the answers. It's clear now.
(PabloR, your choice was the Argentinian vintage style Big Grin )
  Video Editing Is Possible On The PineBook Pro! ImmyChan 12 17,528 11-10-2026, 09:48 PM
Last Post: noahclark
  Updated Pinebook Pro? tantamount 2 2,688 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,471 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,996 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,676 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,164 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 11,135 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 2,206 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 9,089 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,432 06-28-2025, 01:25 AM
Last Post: Www
