U-Boot on SPI flash - discussion
(12-02-2019, 11:09 AM)xalius Wrote: You can write SPI flash from u-boot or from Linux, for emergency recovery even in the PBP, two IC test clips are probably the easiest solution...
By shunting the clock pin to ground?
Yes
While it's not something you're really after, after a lot of frustration and head-scratching I was able to build a working SPI flash image for my fork of U-Boot:
[Image: nz86P8H.png]
I ended up using Rockchip's firmwareMerger with the following config to build the image:
[System]
FwVersion=19.12.03
BLANK_GAP=1
FILL_BYTE=0
[UserPart1]
Name=IDBlock
Flag=0
Type=2
File=rkbin/bin/rk33/rk3399_ddr_933MHz_v1.24.bin,rkbin/bin/rk33/rk3399_miniloader_spinor_v1.14.bin
PartOffset=0x40
PartSize=0x7C0
[UserPart2]
Name=uboot
Type=0x20
Flag=0
File=u-boot.img
PartOffset=0x4000
PartSize=0x2000
[UserPart3]
Name=trust
Type=0x10
Flag=0
File=out/sd/trust.img
PartOffset=0x6000
PartSize=0x2000
For some reason, firmwareMerger from Rockchip repository doesn't work properly, so I had to use the version from Radxa's repository to get proper image.
It should also be possible to use U-Boot TPL and SPL instead of Rockchip blobs, but haven't found any concrete answer on how to build the image using these. Documentation just isn't clear enough, and recovery process is too cumbersome and annoying.
dd is good enough for flashing the image to the SPI. Just make sure to use flash_erase beforehand.
In case something goes wrong and PBP gets stuck somewhere in early boot, the easiest recovery method I found is taking off the metal shield and shorting SPI clock to ground until ARM Trusted Firmware (BL31) initialization. After Linux boots, you can just use dd or flash_erase to reflash/erase the chip.
Overall, it works fine on my device, so there's no more eMMC in my Pinebook Pro Smile
You can find the image here. The build scripts for everything are here.
So if I just flash that SPI image, it will boot directly from SD, then NMVe and then eMMC? No other uboot flash for eMMC is needed?
@pcm720, Thank you for both trying and making your results available to all.
Does your SPI version support booting off SD card if one is installed?
Edit: Never mind, just read your latest post in the "U-Boot with direct NVMe boot support", it answers yes, we can boot SD cards with your SPI image.
Arwen Evenstar
Princess of Rivendale
Yes. However, pre-made SD images do not work:
[Image: tTMBMZP.png]
For some reason Rockchip's SPL tries (and fails) to initialize trust mode with the microSD, so it must not contain any of the bootcode.
In other words, SD has to be partitioned just like any block device. The same most likely goes for the eMMC.
(12-03-2019, 06:18 AM)pcm720 Wrote: Yes. However, pre-made SD images do not work:
For some reason, Rockchip's SPL tries to use SD card and fails to initialize trust mode, so the microSD should not contain any of the bootloaders.
In other words, SD should be partitioned just like any block device. The same most likely goes for the eMMC.
So, it will not boot SD cards like Ubuntu or Debian or any of other PBP images? How to fix that?
edit: answer: here: https://forum.pine64.org/showthread.php?tid=8439
Maybe a silly question, but is the SPI flash not clippable? I haven't seen the hardware itself so I don't know. If one can use a pomona clip and flashrom or s/t then it's a fairly easy recovery.
#19
(01-05-2020, 11:19 PM)aaspectre Wrote: Maybe a silly question, but is the SPI flash not clippable? I haven't seen the hardware itself so I don't know. If one can use a pomona clip and flashrom or s/t then it's a fairly easy recovery.
The Pomona 5250 clip works well. There are cheap knockoffs but the reviews of them are not favorable. The authentic version runs about $15.50 USD before shipping. If you are in the US, you can pick one up at Grainger and save yourself shipping.
#20
Well, I happen to have one of those already, nice. I guess I'm already set to experiment without worry.
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 389 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 870 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 21,788 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 13,917 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 10,406 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 3,410 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 4,514 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 3,012 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 6,887 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,186 01-16-2024, 09:17 AM
Last Post: jbradley419
