Pinebook Pro Audio Codecs
Something they don't really cover, or I haven't been able to find where it is, is what audio codecs will this work with? Aptx hd, LDAC, AAC or SBC? hoping for Aptx hd
(09-05-2019, 10:57 AM)CryptoRick Wrote: Something they don't really cover, or I haven't been able to find where it is, is what audio codecs will this work with? Aptx hd, LDAC, AAC or SBC? hoping for Aptx hd
It's likely using the same wifi/bluetooth module as the RockPro64 adapter:
https://store.pine64.org/?product=rockpr...4-1-module
It seems to use a Broadcom BCM4359 wifi/bluetooth module.
You may be able to see what codecs are supported in hardware, but I would not assume a Qualcomm proprietary audio codec is likely to be supported in an older broadcom chip.
The Pinebook Pro uses a Ampack AP6255 module, which internally is effectively a Broadcom BCM43455. So, you're actually pretty close except that the 43455 is 1x1 WiFi. But that does not change the Bluetooth capabilities in any way.
To the best I can tell, most of those Bluetooth audio codecs are dependent solely on the software (with maybe the exception of AptX), so it will probably depend on what distro you have installed on your PBP.
Do any distros that you know of support any lossless format? LDAC is sony but I read somewhere it was ported.
  Updated Pinebook Pro? tantamount 2 2,262 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,012 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,739 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,309 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 6,750 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 10,608 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 1,924 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 8,770 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,169 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 29,756 03-09-2025, 11:17 AM
Last Post: davisthomas
