Pinebook pro, kali linux.
Is it possible to put a working version of kali linux on pinebook pro?
(08-19-2019, 04:55 AM)Kobalt Wrote: Is it possible to put a working version of kali linux on pinebook pro?
There was a post the other day about this:
https://forum.pine64.org/showthread.php?...light=kali
(08-19-2019, 06:15 AM)evilbunny Wrote:
(08-19-2019, 04:55 AM)Кобальт Wrote: Можно ли поставить рабочую версию kali linux на pinebook pro?
На днях было сообщение об этом:
Спасибо
Well, you can take the Kali build for RockPro64, exchange the dtb + kernel image + /lib/modules ... and it will work
a czy aircrajck-nng da się zainstalować? czy karta wifi jest w stanie wejść w tryb admina? (czyt. wysłąc dowolny pakiet)
Is there anyone who has already done this and could make a tutorial for this (or even post the modified image)? Would be really greatful. Also, am I right thinking that kali 2020.1 will bring official support for the pinebook pro?
Hi Luke,
when you say the Kali Build for RockPro64, I have had a look in the Kali Downloads and the only build listed under PINE64 section (https://www.offensive-security.com/kali-...rm-images/) is for PineBook.
Is this the build you mean? or is there another source for RockPro64?
The dtb + kernel and the /lib/modules; I'm assuming that they are from the "stock" debian build (mrfixit) that shipped on the PBP?
I'd like to give this a try, but need to make sure I'm hacking the right files and image together (as I'm relatively new to linux)
Cheers
G
Linux n00b trying to learn.
Brute force and ignorance sometimes works!
| Pinebook Pro + Toshiba OCZ RC100 240GB |
https://gitlab.com/kalilinux/build-scripts/kali-arm has some info but no script for Pinebook Pro.
As of today, https://gitlab.com/kalilinux/build-scripts/kali-arm was updated with a Pinebook-pro script
There are several, already working Debian options for the PBP, including Daniels excellent work at wrapping the native installer with PBP-aware scripting. With these as a base, why not use “Katoolin”? This will install all the Kali tools and references on a deb based installation of any OS.
https://github.com/LionSec/katoolin
I haven't yet installed myself, but I have new Debian Bullsye Gnome3 systems now, one aarch64 native and one with armhf userspace. Going to give it a try.
A decent article on what you may expect:
https://www.tecmint.com/install-kali-lin...tu-debian/
I hope this is helpful!
— Jeremiah Cornelius
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 11,961 08-09-2025, 06:53 AM
Last Post: Sb2024
  Can’t login to Linux fnosai 0 2,004 07-27-2025, 12:30 AM
Last Post: fnosai
  Boot Order in Pinebook Pro food 11 10,341 03-28-2025, 10:08 AM
Last Post: DrYak
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 2,014 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 4,291 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,530 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 2,742 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,015 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 8,594 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 11,351 02-22-2024, 04:02 PM
