boot times
has there been any testing to determine average boot up times in Linux and android?
(12-10-2015, 03:34 PM)mr_ada Wrote: has there been any testing to determine average boot up times in Linux and android?
The current boot time for Android Loliipop 5.1.1 build is around 40 seconds and plan on reduce down to 25-30 seconds.  For Linux, this highly depends on the build and what type of drivers to bring up, light build should able to boot up on few seconds. In general, Android build is "thicker" than Linux.
I guess android wouldn't work for me.  I was able to get my galaxy tab 7 down to 19 seconds boot up time in Android (cyanogen mod).  Still not acceptable.  There was a demo back in 2011 from linutronix that showed a Qt-based app that cold booted up in under 2 seconds.  Using ARM9 AT91SAM9G45 @400MHz.  Your product has much more power.   Check it out:
https://youtu.be/rhjS8ZONE74
I'd want this most "slim" linux version to run.
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 6,801 05-19-2023, 07:43 AM
Last Post: crocspot
  Pine A64 does only boot with Android 5.1 Dude 6 11,056 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 11,236 02-23-2021, 05:33 PM
Last Post: thedu
Exclamation Can't boot when SD card inserted kivox 5 13,280 03-15-2020, 06:00 AM
Last Post: kivox
  Boot from HDD via usb BnEc 1 5,979 11-29-2019, 04:39 AM
Last Post: evilbunny
  Pine A64 stuck in boot process joey 1 5,722 05-28-2019, 09:07 PM
Last Post: joey
  Won't power on/boot -- kickstarter A64 2GB fuzzycuffs 3 10,134 02-22-2019, 03:25 AM
Last Post: GaryFunk
  boot loop with lcd plugged in drock 0 3,600 01-09-2019, 01:37 AM
Last Post: drock
  LED flashes for 1 second, board won't boot Audioslave 2 7,160 08-02-2018, 10:28 PM
  short boot time after power-up bongo 7 17,061 10-31-2017, 08:02 AM
Last Post: bongo
