Clusterboard networking problems
#21
(03-27-2019, 01:40 PM)bergera Wrote: is there a link to the solution? I went through the ones in the thread but don't see something that I recognize.
It involves going in over the GPIO pins.  If you just want a working image check this out:
https://bit.ly/2Ts2yGL
#22
thanks for the image!
I don't mind editing via serial, so if you have info on that please pass it along as well
#23
(03-27-2019, 02:11 PM)bergera Wrote: thanks for the image!
connect to GPIO over serial:
https://forum.pine64.org/showthread.php?tid=7285
go to /boot/dtbs/allwinner and convert the baseboard DTB with:
dtc -I dtb -O dts -o <temp name>.dts <whatever the prefix>-sopine-baseboard.dtb
under "ethernet@1c30000 {" in the list before "mdio" add the line:
allwinner,tx-delay-ps = <500>;
allwinner,rx-delay-ps = <500>;
then covert back with:
dtc -I dts -O dtb -o <whatever the prefix>-sopine-baseboard.dtb <temp name>.dts
#24
The biggest issue the Clusterboard is facing is users... there aren't enough people who enough development knowledge using it to get past these teething issues, which is why it's great to see AZClusterboard doing the guides. It seems that things are finally moving along at last, it was only six days ago that this was incorporated into Armbian, which apart from apparently fixing SPI, also applies the PHY_RTL8211E_PINE64_GIGABIT_FIX needed to fix up networking... so it will hopefully turn up outside of their development builds soon Smile
#25
(03-30-2019, 03:45 AM)pfeerick Wrote: The biggest issue the Clusterboard is facing is users... there aren't enough people who enough development knowledge using it to get past these teething issues, which is why it's great to see AZClusterboard doing the guides. It seems that things are finally moving along at last, it was only six days ago that this was incorporated into Armbian, which apart from apparently fixing SPI, also applies the PHY_RTL8211E_PINE64_GIGABIT_FIX needed to fix up networking... so it will hopefully turn up outside of their development builds soon Smile
Having those fixes in would make this an awesome board, assuming it makes the clusterboard work with the latest versions of Stretch.
Until then, the baseboard/SOPine combo seems to boot stretch with no issues, so you can play with that if you need a working SOPine module with the latest and greatest OS.
#26
I can confirm that Armbian works out of the box building off armbian/build's master branch
  Managed Ethernet switch on the Clusterboard dsimic 6 16,282 01-16-2024, 02:05 AM
Last Post: hazcam
  Selling Clusterboard + 4 sopine xblack86 7 14,124 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 5,353 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 27,437 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 11,877 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 5,516 05-25-2021, 10:28 AM
Last Post: TechDragon
Information Clusterboard Guide AZClusterboard 9 35,068 04-06-2021, 06:32 AM
Last Post: poVoq
Brick Clusterboard CAD drawings TeaPack 1 6,806 03-31-2021, 01:38 PM
Last Post: Pine
  New Clusterboard Setup wargfn 5 14,176 01-01-2021, 10:10 AM
Last Post: poVoq
  Clusterboard does not even turn on? poVoq 3 10,628 08-15-2020, 07:31 AM
Last Post: poVoq
