How to get text boot on KDE Neon
Hello everyone,
happily writing from my brand new 11' pinebook. Everything works and since there are not many distros with full support I think I'll stick with the default KDE Neon for now.
I am however a sucker login shells and boot messages, so I'd like to tell grub to boot into command like and not showing a splash screen. How do I do it?
I come from Ubuntu (/etc/default/grub into update-grub) and Arch linux (same but with grub-mkconfig), but none of the methods I know worked. I found /etc/default/grub.d/99_breeze-grub.cfg but after editing it I have no idea how to confirm the changes. Can anyone help me?
There is no grub, uboot is the bootloader.
Okay, I wasn't sure but I found grub commands and config files and got mislead.
Is there any way to boot to a login shell on uboot then?
Edit: I'm not actually sure if uboot is even the right approach to this; I've tried disabling KDE and X in general on startup in various ways but nothing seems to work...
(11-13-2018, 02:46 AM)maldus Wrote: Edit: I'm not actually sure if uboot is even the right approach to this; I've tried disabling KDE and X in general on startup in various ways but nothing seems to work...
Do you know about ayufan's minimal images?
https://github.com/ayufan-pine64/linux-build/releases/
Why not just switch to tty2 ? - ctrl+alt+f2
I was under the impression that most builds beyond KDE Neon did not support every feature for the new 1080 Pinebook (for now). Anyway I have a 64GB EMMC to use so I'm eventually going to install something else, I just wanted to first try it out with its default image.
Quote:Why not just switch to tty2 ? - ctrl+alt+f2
Yes, I can do that. I can then proceed to kill KDE if I want, but it feels a bit hackish. There must be a way to prevent X from running on startup, no?
Edit: just found it. I need to disable sddm service (systemctl disable sddm). Now it boots on the login shell, but while it does the screen stays black. Is it possible to have system messages printed during the boot process?
  Latest images from different distros failing to boot from SD card jmonty42 2 6,765 11-17-2020, 09:32 AM
Last Post: pagesix1536
  Pinebook 1080p / KDE Neon freezes every 5-10 min pyrrhumain 12 25,682 11-02-2019, 10:03 AM
Last Post: rookieone
  KDE Neon Image - Where can i find the Kernel Source ? matze79 4 12,863 08-14-2019, 04:27 AM
Last Post: matze79
  Ethernet not found. error during boot Surehand53 1 4,820 07-24-2019, 05:00 AM
Last Post: ObviousHobbit
  Manjaro hangs on boot DAMO238 1 5,007 07-08-2019, 08:14 AM
Last Post: DAMO238
  Adding coherent_pool to boot.cmd on Xenial Mate by Ayufan causes boot loop k_mp 0 3,148 06-11-2019, 01:36 PM
Last Post: k_mp
  KDE Neon Pinebook remix edition RC image bshah 67 163,929 05-18-2019, 11:44 AM
  Blank Screen on Boot MECZero 4 10,729 05-12-2019, 11:54 AM
  MAME on Standard KDE Neon Corkonian 2 5,447 12-19-2018, 02:06 AM
Last Post: Corkonian
  Pinebook 1080 brand new kde Neon Snaps jwp1000 0 2,999 11-21-2018, 06:38 AM
Last Post: jwp1000
