MAME on Standard KDE Neon
So I tried to install MAME on the Pinebook. Would be nice, to have some games around and MAME should be lightweight....
So, after installing and basically configuring, I tried to start my first game
$ mame -nojoy galaga
... and what did I get?
libGL error: unable to load driver : sunxi_dri.so
Angry
I thinkany kind of openGL application is going to encounter this type of problem unless explicitly compiled with sunxi / Mali GPU support.
I guess the best option to get MAME running would be to get Retroarch running but this is being worked on here: https://forum.pine64.org/showthread.php?tid=6940
Well, I have a number of Raspis and they run MAME well. As I only have two Pinebooks and want them to be able to do some productive work, too, I do not want to switch to a completely different Linux distro that comes with it's own set of issues. Swapping mini SD's ain't too good either. I have a Pinebook, because I use it while being OOO. Those micro SD's are, well, a bit too fiddly and get lost easily.
I just want a bloody system that has Mali GPU in the Kernel and that basically just uses what's in it. Even worse, this is not by any means a "new" problem, this is ongoing. Ongoing for a bloody long time.
  Pinebook 1080p / KDE Neon freezes every 5-10 min pyrrhumain 12 28,770 11-02-2019, 10:03 AM
Last Post: rookieone
  KDE Neon Image - Where can i find the Kernel Source ? matze79 4 14,509 08-14-2019, 04:27 AM
Last Post: matze79
  KDE Neon Pinebook remix edition RC image bshah 66 181,633 05-18-2019, 11:44 AM
  Pinebook 1080 brand new kde Neon Snaps jwp1000 0 3,434 11-21-2018, 06:38 AM
Last Post: jwp1000
  KDE Neon problems persisting (1080) ImmortanJoe 8 15,992 11-18-2018, 02:22 AM
Last Post: ImmortanJoe
  activate repository in kde neon Luca Tansini 1 4,633 11-15-2018, 09:57 AM
Last Post: Luke
  How to get text boot on KDE Neon maldus 5 11,917 11-13-2018, 04:29 AM
Last Post: maldus
