Linux Images (ROCK64)
#21
(08-21-2017, 09:20 PM)MarkHaysHarris777 Wrote: The Pine engineers think in terms of Android only;  the gnu+linux images are going to be coming from the community, not Pine.
I imagine it would be easier for Pine to get a NDA+DataSheet to [re]implement drivers then some community member.
I wonder if the rock64 will be the first ARM SBC to have 4k h265 + Wayland or if this disappointing vendor stance will slow it down.
Rockchip is very active to have proper linux support going, so the chances are bigger than ever.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
ayufan latest Linux Images (0.5.9-104) for ROCK64. Please visit his GitHub for released notes and visit the related links below on our Wiki:
Community Build Debian Stretch Minimal Linux Kernel ver 4.4 [microSD Boot]
Community Build Debian Jessie Minimal Linux Kernel ver 4.4 [microSD Boot]
Community Build Xenial Mate Linux Kernel ver 4.4 [microSD Boot]
Community Build Xenial Minimal Linux Kernel ver 4.4 [microSD Boot]
Community Build Jessie OpenMediaVault Linux Kernel ver 4.4 [microSD Boot]
Community Build Xenial i3 Linux Kernel ver 4.4 [microSD Boot]
Any update on the stock LXDE build with sound fixed? Thanks.
(09-19-2017, 07:13 PM)Farley56 Wrote: Any update on the stock LXDE build with sound fixed? Thanks.
Maybe xenial-minimal-rock64-0.5.10-118-arm64.img.xz
sudo apt-get install xorg lxde lxdm lxsession-logout chromium-browser
sudo reboot
sudo reboot
Ran the commands on Ayufan's armhf version of Xenial Minimal -130 as I need to be able to install the JRiver MediaCenter software on it. Now I get a slow flashing cursor in the upper left, not desktop, no terminal login, nada. Could be the 130 build but I doubt it. I'll play some more. Thanks for the info though, didn't think to just add the desktop. Doesn't let the Pine folks off the hook to get the sound working on the stock LXDE build though does it. Smile
sudo reboot
The prerelease have a problem with the mali and xorg as a startx shows.
I think they are prerelease and I am playing catchup but not ready to start with those.
I posted that as I have already had it working fine with the release img, haven't done well with the prerelease.
I have been trying to get Lubuntu-QT up and running and with tests got LXDE running with the above.
[EDIT]
Nope HF just did the same so must of been Arm64 as was working on it for a couple of hours and chromium and LXDE worked fine.
ayufan latest Linux Images (0.5.10-118) for ROCK64. Please visit his GitHub for released notes and visit the related links below on our Wiki:
Added Community Build Xenial Mate Linux Kernel ver 4.4 [microSD to eMMC Boot] [0.5.10-118]
Added Community Build Jessie OpenMediaVault Linux Kernel ver 4.4 [microSD to eMMC Boot] [0.5.10-118]
(10-02-2017, 03:32 AM)pineadmin Wrote: ayufan latest Linux Images (0.5.10-118) for ROCK64. Please visit his GitHub for released notes and visit the related links below on our Wiki:
Great idea for the sd->emmc transfer images Ayufan. Thnx.
Hello, this image is great, but I would like it to be the ARMHF version. Is there any way to make it or convert it from microSD boot image? thanks
Enviado desde mi MI 5s Plus mediante Tapatalk
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 11 16,120 12-06-2025, 01:32 PM
  Xen hypervisor on Rock64 tumbleweed 6 10,023 11-03-2025, 09:25 AM
Last Post: darkfader
  Rock64 - not booting after Armbian update helpmerock 6 3,854 03-27-2025, 08:26 AM
  can rock64 4gb ram run entirely on free software? heocb 1 2,438 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,564 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,625 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 70,961 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 101,116 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 4,622 03-14-2024, 03:09 AM
  Rock64 won't boot dstallmo 0 2,694 12-27-2023, 10:34 AM
Last Post: dstallmo
