Xen hypervisor on Rock64
I'm trying to install the Xen hypervisor on rock64, starting with the info at Xen ARM with Virtualization.
Here are the steps I followed so far:
  1. Installed a minimal debian stretch image on the rock64 mmc (thanks @ayufan !)
  2. Built Xen on rock64 (for XEN_TARGET_ARCH=arm64)
  3. Used mkimage to prep xen for uboot: mkimage -A arm -C none -T kernel -a 0x00800800 -e 0x00800800 -d dist/install/boot/xen xen-uImage
  4. Modified //boot/efi/extlinux/extlinux.conf  to add a custom configuration that loads the xen kernel (xen-uImage) using the same dtb that came with the stretch image (see config code below)
  5. Reboot with serial console attached, select my custom extlinux configuration
  6. rock64 hangs (serial output stops) at "Starting kernel ..."
As far as I know, nobody has written up a guide to doing this, on any RK3328 board, and it's my first time trying.
Anyone have suggestions on what I might try next to get past this hanging problem?
label kernel-xen    kernel /xen-uImage    initrd /initrd.img    fdt /dtb    append earlyprintk=uart8250-32bit,0xff130000 rw root=LABEL=linux-root rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=${ethaddr} eth1addr=${eth1addr} serial=${serial#} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
(05-13-2018, 09:03 PM)tumbleweed Wrote: Anyone have suggestions on what I might try next to get past this hanging problem?
I haven't tried xen on arm, but there are builds for docker and kubernetes, are these an option for you?
Thanks for the reply.
The goal is to run a unikernel under the xen hypervisor.
Similar to running containers, but not the same.
Is there another forum you’d suggest for posting this question?
Hi Tumbleweed,I haven\'t tried Xen on Rock64, but I did run Xen on Pine64 successfully in the past.The mkimage step below is only required if you boot Xen from U-Boot. If you boot Xen from extlinux or another bootloader, it will actually cause troubles. Instead, to simplify the boot sequence, I would boot Xen directly from EFI, skipping extlinux completely. To do that, you need to copy xen.efi to the FAT partition, and write a xen.cfg config file. You also need to copy the Dom0 kernel, initrd and device tree to the fat partition. For instance, see this guide for booting Xen on ARM on QEMU:https://wiki.xenproject.org/wiki/Xen_ARM_with_Virtualization_Extensions/qemu-system-aarch64There are a few QEMU specific steps in there, but it also contains the steps to boot Xen directly from UEFI including an example xen.cfg.It might also be possible to boot Xen from extlinux but I don't have experience with that. I recommend booting from UEFI first. Cheers,Stefano
(05-13-2018, 09:03 PM)tumbleweed Wrote: Hello,
Hi sstabellini, thanks for the suggestions.
I tried to setup direct UEFI boot without success.  (Basically I started with the QEMU instructions and created  /boot/efi/EFI/xen/ with xen.efi , xen.cfg and so forth. )
It appears that EFI booting is skipped altogether, and for example:
rock64@rock64:~$ efibootmgr -w -L Xen -l "\EFI\Xen\xen.efi" -c EFI variables are not supported on this system.
Looking at the Rockchip boot options diagram, it appears that either u-boot.bin or UEFI.FD is run as "Loader 2" , only for "Boot Flow 1".  Looking at the serial console output below, it seems to me the Rock64 is following "Boot Flow 2", which uses u-boot, since we see "BL31" running.
The serial console output at reboot, if I read it correctly, shows the system directly booting into u-boot.
How can I ensure the Rock64 chooses UEFI boot?
=> reset DDR version 1.08 20170628 In SRX LPDDR3 333MHz Bus Width=32 Col=11 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=4096MB ddrconfig:7 OUT U-Boot SPL 2017.09-ga0a2b48 (Apr 29 2018 - 20:24:03) setup_ddr_param  1 booted from eMMC Trying to boot from MMC1 NOTICE:  BL31: v1.3(debug):9d3f591 NOTICE:  BL31: Built : 14:39:02, Jan 17 2018 NOTICE:  BL31:Rockchip release version: v1.3 INFO:    ARM GICv2 driver initialized INFO:    Using opteed sec cpu_context! INFO:    boot cpu mask: 1 INFO:    plat_rockchip_pmu_init: pd status 0xe INFO:    BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR:   Error initializing runtime service opteed_fast INFO:    BL31: Preparing for EL3 exit to normal world INFO:    Entry point address = 0x200000 INFO:    SPSR = 0x3c9 U-Boot 2017.09-ga0a2b48 (Apr 29 2018 - 20:24:18 +0000), Build: jenkins-linux-build-rock-64-213 Model: Pine64 Rock64 DRAM:  4 GiB MMC:   rksdmmc@ff520000: 0, rksdmmc@ff500000: 1 Card did not respond to voltage select! mmc_init: -95, time 10 *** Warning - No block device, using default environment In:    serial@ff130000 Out:   serial@ff130000 Err:   serial@ff130000 Model: Pine64 Rock64 misc_init_r cpuid=55524b50303930343000000000010715 serial=9a6b577037c4808 normal boot Net:   eth0: ethernet@ff540000 Hit any key to stop autoboot:  0
Quote:sstabelliniHi Tumbleweed,I haven\'t tried Xen on Rock64, but I did run Xen on Pine64 successfully in the past.The mkimage step below is only required if you boot Xen from U-Boot. If you boot Xen from extlinux or another bootloader, it will actually cause troubles. Instead, to simplify the boot sequence, I would boot Xen directly from EFI, skipping extlinux completely. To do that, you need to copy xen.efi to the FAT partition, and write a xen.cfg config file. You also need to copy the Dom0 kernel, initrd and device tree to the fat partition. For instance, see this guide for booting Xen on ARM on QEMU: https://wiki.xenproject.org/wiki/Xen_ARM...em-aarch64 There are a few QEMU specific steps in there, but it also contains the steps to boot Xen directly from UEFI including an example xen.cfg.It might also be possible to boot Xen from extlinux but I don't have experience with that. I recommend booting from UEFI first. Cheers,Stefano
I was able to get a bit further with loading with the EFI approach.
First I flashed u-boot onto SPI flash.
Then I loaded the xen.efi onto a micro sd card (as bootaa64.efi), stopped the uboot autoboot,
and attempted to manually boot using efi.  This yields the errors shown below -- Any suggestions?
Hit any key to stop autoboot:  0 => set devtype mmc => set devnum 1 => set distro_bootpart 6 => run boot_efi_binary reading efi/boot/bootaa64.efi 885072 bytes read in 128 ms (6.6 MiB/s) libfdt fdt_check_header(): FDT_ERR_BADMAGIC ## Starting EFI application at 02000000 ... Card did not respond to voltage select! mmc_init: -95, time 10 Scanning disk rksdmmc@ff520000.blk... Scanning disk rksdmmc@ff500000.blk... Found 2 disks Xen 4.11-rc (c/s Tue May 1 09:03:13 2018 +0100 git:0306a1311d) EFI loader Couldn't obtain the File System Protocol Interface: ErrCode: 0x8000000000000003 ## Application terminated, r = 0
For reference, here's what's on the sd card:
=> ls mmc 1:6 19644424   image            efi/            extlinux/  2920159   initrd.img    56922   dtb      134   xen.cfg => ls mmc 1:6 efi/boot             ./             ../    885072   bootaa64.efi
The existing Image and dtb boot OK (using /extlinux/extlinux.conf )  but xen does not boot.
Hey,
I know this is an old post but I think the problem is common enough and hard enough to figure.
So when you see this scenario - Xen kernel starting and then just "Starting kernel" with regards to Linux, or not even see the Xen kernel starting.
I went through that last week with a Cubietruck.
It almost always means no more than your output is going to a different or misconfigured or non-existent console.
It does almost never mean there was a failure to execute your kernel.
In my case, I had to _remove_ the whole set of definitions like dtuart, console=dtuart, earlycons et ceterea.
EVERYTHING. just no special setting for Xen, load the correct DTB of course, and for Linux kernel, plain and simple console=hvc0.
From that moment on, I had Xen boot output on serial, then Linux kernel boot output on serial, then Linux console on serial.
There was other issues, mostly Xen vs Kernel vs. xl toolstack mismatches
A non-Xen enabled kernel (alpine-lts iirc) and a few more stupid mishaps.
But the main and most common issue was simply that I could not find any indication it was booting when in fact it was booting (and then failed of course), and that the serial console setup didn't work in the "oh lets do it super perfectly addressing the device from dt" way or any other, but worked perfectly in the default which i had never tried since all instructions very specific about giving a device tree address. Just try not doing that and see how it goes.
There's also reports that some DTB's have pins inverted and stuff like that, I tried reversing tx+rx cables, nope.
The failing setup is more complex than that, but there's no reason (unless you do it commercially) to look into that when you can just not specify it and be done with it.
Best,
Flo
  rAudio for Rock64 V2/Pine A64+ shinzuka 16 6,044 11-28-2026, 02:11 PM
Last Post: shinzuka
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 22,489 09-27-2026, 11:55 AM
  DietPi OS for ROCK64 MichaIng 43 101,086 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,371 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 8,118 01-24-2026, 04:44 PM
Last Post: ff255
  can rock64 4gb ram run entirely on free software? heocb 1 4,239 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,483 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,315 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 121,624 09-01-2024, 06:05 AM
Last Post: RaymondDay
  Rock64 v2 - did not work song / audio sqw200zu 2 6,796 03-14-2024, 03:09 AM
