Android 5.1.1 TV (old-stable, no longer maintained)
hi
I installed this on a spare SD card...no Play Store?
thanks
(10-03-2016, 11:45 AM)howardsternisbatman Wrote: hi
thanks
Play Store is there.
How do i install netflix onto it? I searched the googleplay app but couldnt find it
(10-02-2016, 06:12 AM)ayufan Wrote: gorzany: currently it's impossible to limit to 100Mbps. I plan to add an app that would allow that.
Maybe you have to use better SD card?
You can also try this release: https://github.com/ayufan-pine64/android...es/tag/1.1
thanks for your reply.
I have used 2 different SD cards with two versions -  1.2 and 1.1.
In all cases, i have encountered the same outcome, nothing is working following setting up my google account.
All the Apps were installed automatically after first run, but then nothing is working - i can see youtube recommendations, clock (upper left) and search (upper right)
but they are not responsive..
So far I only used a regular mouse (which worked fine though setup). Huh Confused
today i will try a USB keyboard.
(10-05-2016, 04:02 AM)RedFawkx Wrote: How do i install netflix onto it? I searched the googleplay app but couldnt find it
Download the Netflix apk from the internet on you computer and put it on a flash drive. Put the flash drive in the pine. Use ES File explorer to navigate to the USB drive. Find Netflix apk on USB drive. Install.
thanks
I installed  https://github.com/ayufan-pine64/android...r16.img.gz
Where?  https://goo.gl/photos/iwEmfHPyHHBQgKpA9
thanks
I did not use that image, sorry.
thanks
Which one did you use? Link?
thanks
1.2: jenkins-android-5.1-pine-a64-16
Burned with RasPlex
Is there a particular version i need to download? Or do i get the latest apk which is Netflix for Android TV 3.2.2 build 1470 released August 16 2016?
  Need help compiling android for pine a64 + YeeticusMaximus22 1 956 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 558,626 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 45,285 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 28,808 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,324 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 12,641 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,344 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,910 07-15-2019, 08:29 PM
  Issues with SD Card and Running Android Twistedx 0 6,644 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 149,859 02-10-2019, 07:44 PM
Last Post: mmmarcus
