Android 5.1.1 TV (old-stable, no longer maintained)
#71
(09-14-2016, 02:28 AM)ayufan Wrote: dogger: adb logcat
I figured out the Package Installer issues I was having. For some reason there were 2 "Package Installer" system apps. I disabled one and we are good to go. Now I'm just getting errors when I go into Google Cast settings. I will post the log when I get home. Thanks
#72
Hi there I installed this image on my sd card and put in to pine64 and I'm using sony bravia tv with hdmi when i turn on pine on tv it shows 1080P then after that nothing just blank screen ???
Any help plz ...
TIA
#73
Try connecting HDMI a few times. It sometimes happens that kernel is locked on something and restart helps.
You also need to be very patient, it takes sometime to prepare system.
#74
(09-14-2016, 09:00 AM)ayufan Wrote: Try connecting HDMI a few times. It sometimes happens that kernel is locked on something and restart helps.
Thanks for the reply and I'll trying again n wait, will tell you if i got anything
Cheers mate!
#75
Still no joy with this image, tried several times connecting HDMI and wait aswell but nothing on screen just black screen only when connect it shows 10180p at the start after that nothing Sad
#76
The only way to see what is happening is connecting UART and see what is on serial console Smile
#77
Seems to work verry well, looking forward for the 7.0 version in 4K, and really would like the Ethernet to be fixed to support 1000 MBit
#78
Project-XXX: 4k support is there, but it seems that board is slow to drive that many pixels. You can change the resolution in Development options.
#79
ayufan -> In 7.0 the Development Option constant crashes, so thats why i'll stick to the 5.1.1 for now, but yes the 4K works there.
#80
You need to pass Setup to mark the device as boot complete. This should be fixed in latest release BTW.
  Need help compiling android for pine a64 + YeeticusMaximus22 1 417 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 538,938 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 43,307 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 27,670 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 10,888 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 12,154 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 8,982 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,704 07-15-2019, 08:29 PM
  Issues with SD Card and Running Android Twistedx 0 6,429 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 144,596 02-10-2019, 07:44 PM
Last Post: mmmarcus
