Android 5.1.1 TV (old-stable, no longer maintained)
#41
Hi
Installed your image. I don;t have wifi but seems there is no way passing the 2nd screen * the screen after language selection) without wifi.
network is via the Ethernet cable, no wifi is available.
Any suggestion on how to get passed this screen
#42
mrv: restart and it will get back to normal
#43
Just wanted to shout out a big THANKS to ayufan for making the build and making Pine64 finally get CEC!  Great job!
One thing I wanted to ask was about the overscan adjustments on Android TV - is it something that can be built into the image?  I see examples for other boards (e.g. http://www.howtogeek.com/251934/how-to-a...ndroid-tv/) that allow adjusting the overscan right in the settings.  Is it something doable?
[url=http://www.howtogeek.com/251934/how-to-adjust-overscan-on-the-shield-android-tv/][/url]
Away
#44
The support is there, but it's not exposed.
If someone would add this as separate application we could Sideload it for TV and Regular builds.
Take a look at this application: https://github.com/ayufan-pine64/packages-apps-Settings
#45
Not able to install apps due to lack of space.
How do i resize partitions? Got 11.5gb of unallocated space on sdcard.
#46
Use GParted on SD card
#47
(09-11-2016, 06:29 AM)ayufan Wrote: Use GParted on SD card
I'm on Windows. Can I use mini tool? If so, what should I make the partition? Thanks
#48
dogger: I doesn't know this tool.
Try. The worst what can happen that you will brake your SD card Smile
#49
I spent all day trying to resize the system partition with no luck. I tried using gparted with Windows 7, no luck. I tried with Linux, still no luck, all it would do is boot loop after resizing the system partition. Was I wrong by resizing the system partition?
#50
(09-12-2016, 05:05 PM)ayufan Wrote: dogger: I doesn't know this tool.
I'd rather not break another one. Roasted one on day 1 with the Pine using Remix OS it bootlooped and killed the SD card. I guess I'm asking which partitions I can touch. I'm using a 32gb...
Boot:49MB
Ext3:1.5GB of which 772.58 mb is used
Other: 768mb of which 768 is used
Other 1gb of which 1gb is used
26.5 Unallocated
Obviously I can try to change the unallocated to Ext 4 but I'm wondering if that is correct. Also can I combine it with the 2 "Others"? I added a screenshot of minitool.
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 523,844 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 41,937 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 25,356 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 10,587 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 11,662 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 8,737 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,522 07-15-2019, 08:29 PM
  Issues with SD Card and Running Android Twistedx 0 6,186 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 140,366 02-10-2019, 07:44 PM
Last Post: mmmarcus
  +LTS/SOPINE Android SDK support and Customization biplab777 1 7,089 01-07-2019, 01:21 AM
