Android 5.1.1 TV (old-stable, no longer maintained)
#31
Super cool!
- I had to use 100Mb ethernet - 1000Mbps would not work.
- 4k has the image compressed in the top half of the screen, although colour extends to the bottom sometimes with noise.
- cheap 4k tv doesn't have CEC
screenshot is here: http://imgur.com/a/63kTv
#32
Played with it for a bit. Was definitely able to get my 1000Mbps connection going, which is great. Don't have a 4k to test with unfortunately. Menu seemed quite snappy. Tried to throw Netflix on it, but couldn't find the correct compatible version. Definitely a fantastic start you have with this, please keep er going so it can become my daily driver. Love the fact that I can navigate the menus without the need for a full keyboard. Appreciate all the hard work with this build!
#33
TraJiK: try to sideload Netflix using `adb install`. Download APK from: https://www.apkmirror.com/apk/netflix-inc/
#34
jlongman: I have the same
#35
Gotta get me a bigger sd card realllly wanna mess with this . Only have a 4gb card right now
Sent from my SM-G928T using Tapatalk
#36
Works really well on 1080p TV. Love the Android TV remote control app functionality. Really only could do with some suspend / standby button, as you stated the built in sleep will not wake up. Really awesome build overall, thanks for this.
#37
(09-02-2016, 07:37 PM)TraJiK Wrote: Played with it for a bit. Was definitely able to get my 1000Mbps connection going, which is great. Don't have a 4k to test with unfortunately. Menu seemed quite snappy. Tried to throw Netflix on it, but couldn't find the correct compatible version. Definitely a fantastic start you have with this, please keep er going so it can become my daily driver. Love the fact that I can navigate the menus without the need for a full keyboard. Appreciate all the hard work with this build!
I went to Chrome and searched for netflix, in the google results was a link to the Play store.  Choose the new Netflix (Stylized N on a black background) not the old one (rounder N on a white background).  Click and install, and it's in the Sideloaded Apps app, not the main screen.  No need to sideload with adb.
#38
So it's not Netflix for TV Smile
#39
jlongman: try this one: https://www.apkmirror.com/apk/netflix-in...ndroid-tv/
#40
(08-26-2016, 11:53 AM)VAAviator Wrote: Thank You for doing this work. For many of us,  this is why we bought the Pine64.
Can you give us exact install procedures or create an image that we can just put on the SD Card and run.
My thoughts are with the same as most of us bought the Pine64 for using as Android box. And would be very grateful if someone put video or install procedure step by step.
  Need help compiling android for pine a64 + YeeticusMaximus22 1 1,882 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 587,084 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 48,164 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 30,750 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,147 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,533 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,081 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,429 07-15-2019, 08:29 PM
  Issues with SD Card and Running Android Twistedx 0 7,158 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 157,176 02-10-2019, 07:44 PM
Last Post: mmmarcus
