upgrading u-boot--what version? where to get it?
(05-21-2024, 11:30 AM)bsammon Wrote:
(05-21-2024, 12:28 AM)Pavlos1 Wrote: If you want to have multiple OSes installed on one boot device, I would install Tow-Boot to the SPI because it has a built-in boot selector.
Hah... yeah, it's Tow-Boot that started me down this path. The Tow-Boot install instructions (the ones I read) say it should be installed by creating a bootable-SDCard installer, and then booting from it. Guess what wouldn't boot with my 4-year-old u-boot?
If you're willing to take your PBP apart, you will find an eMMC-disable switch. If you flick that then it should boot normally from a Tow-Boot SD card. (i.e. It will use the bootloader on the SD card instead of trying to use the bootloader on your eMMC to boot the SD card.)
If not, a potential software workaround is to use the rk2aw installer from within your stock (i.e. installed to eMMC) OS, then power off the PBP and insert a Tow-Boot SD card. rk2aw will then automatically boot using the bootloader on the SD card, at which point you can use the Tow-Boot installer to overwrite the existing rk2aw install with Tow-Boot.
(05-21-2024, 11:30 AM)bsammon Wrote: Also, now that I finally have serial console set up, I see that u-boot (at least the version on my PBP) has a built-in boot selector as well.
Tow-Boot will give you a graphical selector (IIRC), so you don't have to plug in the serial adapter for every boot....
If you know how to use dd , AND NOT SCREW-UP, is it not simpler to blank (dev/zero)
the uboot area on emmc? If uboot is not there, then it can't be loaded
DO make a backup of MBR and first 16M so you can restore as needed
It is a bit tedious to type (in uboot terminal) boot_targets=mmc1 or whatever
every time you want to change defaults
What about https://www.bleepingcomputer.com/news/se...otloaders/
This gives me a really good reason to update uboot
(04-01-2025, 07:53 AM)Tazdevl Wrote: What about https://www.bleepingcomputer.com/news/se...otloaders/
Without reading and understanding the code changes (for me, insurmountable at the current time) I don't trust Microsoft's recommendations, let alone Microsoft's AI's recommendations. What I have works.
:wq
https://www.heise.de/en/news/Bootloader-...87520.html
I have no distrust in Microsoft. I work in a field where security and trust is key.
But for sure there are shady folk out there, Oracle stating they where not hacked for instance. Microsoft has a bit of a shady past as well.
  I think you can try compiling the PC version image of OpenHarmonyOS 5 or 5.1 wangyukunshan 2 1,127 01-03-2026, 07:09 AM
Last Post: qingss0
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 676 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 1,143 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 23,647 06-11-2025, 08:53 AM
Last Post: lgmpbp2
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 10,894 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 3,656 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 4,731 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 3,258 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 7,382 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,294 01-16-2024, 09:17 AM
Last Post: jbradley419
