link for supported pinephone os manjharo et all
Hi-
the images at the manjaro site only have a checksum and the site looks funny like no CSS styling is applied.  It is just a bunch of hyperlinks.
Mobian didnt have a way to verify either.
I am desperate for an image. Can someone point me somewhere there is a cool image i can use with the pinephone that is supported?
I like manjaro gnome but v16 aiin't workin.
thanks,
jim
manjaro's github page has .img files for each release, and .sha256 for each .img https://github.com/manjaro-pinephone/phosh/releases
okay that is awesome.
THANKS!
I'm on Beta 36 since march, and now that I'm trying to reinstall Telegram on it, I keep getting oodles of 'not found' etc when it tries to synchronize package databases.
I gave up on Beta 29 because it wouldn't update because of one error (someone's sha signature was not found in the database). While 36 in general works better, this is... well, is there a workaround? I'd need to update just megapixels and to install Telegram.
  New PinePhone user issues greenpineuser 8 7,895 12-19-2024, 09:47 PM
Last Post: emilianojay
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 19,029 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,803 07-03-2024, 08:38 PM
  systemic issue pinephone penguins_rule 3 4,773 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 7,489 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 8,634 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 18,868 02-04-2023, 08:35 PM
Last Post: Westslope
  How to install iptables extensions? I get "Extension owner revision 0 not supported" anon4 0 5,026 08-27-2022, 12:19 PM
Last Post: anon4
  Pinephone craches after each call neithan76 2 4,220 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 52,841 07-28-2022, 12:40 PM
Last Post: johaennessen
