Brand new Pinebook Pro doesn't boot after Manjaro update
I need a fleet of low cost laptops for a factory floor and am evaluating the PineBook Pro.
I received my unit today, booted it up, set up the user account and was happy with how painless it was. Then the software updater in Manjaro said there were a bunch of updates available so I hit the button to update. The computer rebooted as a part of this process and now it will no longer boot. I get the power LED and nothing on the screen.
Where do I go from here? Are software updates on this thing generally a dicey proposition?
From what I've seen, this only happens once. After you get it working, and keep it updated, it shouldn't be an issue.
In any case, all these problems only seem to happen with Manjaru.
Keep in mind that the power light doesn't really indicate "power on". It indicates that some software turned it on. So you can roughly determine at what point the boot process stopped. You *might* be able to make a bootable SD card and recover the system from there. At least some versions of U-Boot that come with Manjaru do not allow you to boot that way. But it's worth a try; you should have a bootable SD card for emergency boot purposes anyway.
You can find bootable images in the wiki. The one I've used successfully for this purpose is DietPi.
:wq
Same thing happened to me today.
Brand new unit, pacman - Syyu, now the power light comes on and nothing else happens.
I don't have a SD card lying about, so it's bricked for me.
The ultimate fix for this would be to ship the Pinebook Pro without an operating system installed. But this would force everyone to have a micro-SD card solution anyway.
Really, this is a hobbyist computer and needs other resources to support it. The minimal support resources would be a micro-SD card and a way to write an appropriate image to it.
If I needed an array of laptop computers for a specific purpose, I wouldn't hesitate to use the PBP. This is based on my experience using them. I use NetBSD on both of mine, but I do have Manjaru on my wife's. I did have to struggle with the default Manjaru installations. But once I got them up and running, I haven't had any issues since. And I do thrash my PBPs with NetBSD pretty well.
I actually thought of this yesterday, being at a contesting station with four networked laptops for collaborative logging. Except that the specific software running required Windoze, I couldn't help thinking how much better four PBPs would have been, especially seeing the admins struggle to get them going after power outages.
:wq
I completely agree with you there.
I’ve got back-up micro-SD cards for each device with their best working versions, then another folder in Syncthing with my customizations, modifications & files, so there’s always a backup copy on my server for each one during testing (for when I break something); it just makes life so much easier.
PinePhone, Pinebook Pro & PineTab2 owner.
(06-13-2023, 04:36 PM)johnboiles Wrote: I need a fleet of low cost laptops for a factory floor and am evaluating the PineBook Pro.
This actually happened to me last night. I was running a really old copy of Manjaro XFCE, and it appears I had a really old version of U-Boot also. I did a major update... and it was bricked.
I believe there was a major update for Manjaro v23 that requires a newer copy of U-Boot, and for whatever reason that doesn't get updated. (This one doesn't know how to update U-Boot in general). I suspect this is the case, since I now flashed my emmc with Manjaro v23, and I now have a U-Boot icon in the upper right hand side during boot.
If someone could explain how to fix without doing a re-flash (like I had to do)... that would be nice! Big Grin
AFAIK only mrfixit actually wrote the uboot package to "right" place, manjaro, as is
common dumps it into /boot,, THEN you are supposed to do the dd write yourself
Fot the OP, if there is an automatic reboot, update ONLY uboot (and do the dd write),
then do full update
How you are supposed to know all this, I can't imagine
(12-14-2023, 04:35 PM)wdt Wrote: >and for whatever reason that doesn't get updated
then do full update
Someone please put this in the wiki, or something!
:wq
And some of the earlier manjaros,most obnoxiously, overwrote extlinux.conf, with no warning,,,
rather than writing a .pacnew.. Sometimes this didn't work, and since there was no notification,
you had no idea why
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 2 5,681 08-10-2025, 10:35 PM
Last Post: Pattienner
  Pinebook problem meghancordo 1 3,088 07-24-2025, 07:28 AM
Last Post: mikehenson
Question Printing and scanning documents with pinebook? Www 0 2,812 06-28-2025, 01:25 AM
Last Post: Www
  Pinebook Pro in EU for Sale - €90 jan_vdk 4 5,857 06-19-2025, 02:14 AM
Last Post: shelfaberrant
  3 days in, slow/stuck or no boot. lgmpbp2 34 17,628 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 11,300 04-03-2025, 07:47 AM
Last Post: Tazdevl
  Pinebook64 Pro doesn't power on andrea_from_italy 9 4,374 03-20-2025, 10:07 AM
  Pinebook pro bricked? michaelmoua 2 3,573 03-12-2025, 11:09 AM
  Use SD to install new OS over pinebook debian Rudy558 10 20,812 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 3,630 02-05-2025, 03:56 AM
Last Post: waylonwesley
