Real/Usable USB-C battery pods for Pinecil? (9-12v mode minimum)
There is this one USB-C PD battery pack that I like because it doesn't have cables.
It's Veger 20W mini powerbank from Amazon
It negotiates 12V, and so it reaches 15W .  It also nicely fast charges a smartphone.
[Image: 861b1ae9-9697-43f4-a782-f835e7639b53.jpg]
(07-09-2022, 03:40 PM)dzid26 Wrote: There is this one USB-C PD battery pack that I like because it doesn't have cables.
For my use cases I am not sure I would want that exact setup, but thanks for that lead!
I wonder if it might make more sense to get one of those big power stations with AC output and just use one of the PINEPOWER USB-C PD devices or similar? It's not super light but get a decent USB-C PD cable and you could pack it into a backpack and use it for a decent while without charging.
I just ordered one of these, supposed to do 300W(600 peak watts) and has a notably larger battery than a small power pack. I think the amps can be sustained for up to 4 meters (with only USB2.0 speeds but the current will carry) so you could operate it from a pack if you couldn't seat it on the table.
The model is a Jackery Explorer 300 - there were discounts for prime day. Could post a link but I don't want to come across as some kind of shill.
Good luck!
it doesn't get happy
it doesn't get sad
it just runs programs
(07-17-2022, 02:14 PM)zer0sig Wrote: I wonder if it might make more sense to get one of those big power stations with AC output and just use one of the PINEPOWER USB-C PD devices or similar? It's not super light but get a decent USB-C PD cable and you could pack it into a backpack and use it for a decent while without charging.
Good luck!
That Jackery battery seems interesting though a bit big for my plan to have a power bank in my portable tech tool box.  At that size I would also want a solar power charge controller; though I would probably want that and the 220v inverter as plug-ins to keep the size smaller should I want a larger portable system and that would again lead me to a DIY solution I think.  That big I would probably want to move on and build an add-on to a removable(I have not investigated electrical personal locomotion battery standards at all) E-bicycle battery cartridge.
The 600watts is pretty extreme over a USB cable, maxxed at 20v that is 30amps though those tiny USB-C cable wires and connectors!!
https://en.wikipedia.org/wiki/Quick_Charge
I'm using a Baseus 65W 30,000mAh power bank. It was pricey, but lasts for ages. It heats the Pinecil to 340c in about 12 seconds using the red Pincil silicone USB C cable.
(08-02-2022, 10:13 PM)Flux-Sniffer Wrote: I'm using a Baseus 65W 30,000mAh power bank.  It was pricey, but lasts for ages.  It heats the Pinecil to 340c in about 12 seconds using the red Pincil silicone USB C cable.
Several IP5328 boards have arrived, I have some 18650 cells so I will decide how best to construct a Pinecil compatible battery pod.  It is unfortunate that this process of selection is so fraught, though at least there are some tested off-the-shelf options vs bring-your-own cells options.
I am thinking about using a 40V 5AH lawn tool battery.  Connect this 200/400W buck convertor to it  https://www.aliexpress.com/item/3256804006119819.html and mount this fan onto the buck convertor heat sink https://www.aliexpress.com/item/3256801789237445.html This would give me a very strong 12V - 24V output.  And then maybe a Baseus 100W or 160W car charger for ports.  I keep worrying about the size of this beast, and if I really have any use for it.
(07-19-2022, 04:13 AM)biketool Wrote: That Jackery battery seems interesting though a bit big for my plan to have a power bank in my portable tech tool box.  At that size I would also want a solar power charge controller; though I would probably want that and the 220v inverter as plug-ins to keep the size smaller should I want a larger portable system and that would again lead me to a DIY solution I think.  That big I would probably want to move on and build an add-on to a removable(I have not investigated electrical personal locomotion battery standards at all) E-bicycle battery cartridge.
That's 600W peak over a NEMA 5-15 standard AC plug. 60W USB-C PD.
it doesn't get sad
Warning, this is Not a Pinecil, this was not made by Pine64 .  This is a fake copy.   See warning in Pinecil Wiki  https://wiki.pine64.org/wiki/Pinecil#Authenticity
Also see in the   Github firmware IronOS   warning about it https://github.com/Ralim/IronOS/discussions/1257
Avoid QC, look at Power Delivery Protocol (PD), do not get anything that delivers less than 3amps (more is ok/good).
Pinecil Wiki has an entire section on Power https://wiki.pine64.org/wiki/Pinecil#Pow..._and_Watts
and links to Community Chat where the very active and knowledgeable volunteers hang out.
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 657 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 833 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,152 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 8,793 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 4,622 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 1,201 05-15-2025, 01:35 AM
Last Post: autumnharris
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 0 1,786 03-22-2025, 07:29 AM
Last Post: BigCarrotLeaf
  Pinecil constantly cutting out WroughtIron 1 2,674 01-16-2025, 02:20 AM
Last Post: D4veC4rter
Exclamation Pinecil is working with 5v but nothing else!! MizterPink 1 1,866 01-07-2025, 03:59 PM
Last Post: MizterPink
  Pinepower suitable for an s23 (and a pinecil) its_lieseeeee 0 1,431 12-09-2024, 01:41 PM
Last Post: its_lieseeeee
