Asus laptop power supply can also power Pinecil
While waiting for my pine power to arrive I noticed that the standard barrel tip power supply from all of the Asus laptops we have had from the last ~7-10 years are compatible with my pinecil.
I had noticed we had ripped some probes from a logic analyzer and was excited to get my pinecil hot after finding on arrival that the pinecil would not heat up connected to 5v USB C.
What a great mini soldering iron, it was able to dial up to 20v when connected to the Asus power supply and heated up to 300C in less than ten seconds.
Ergonomics with a right-angle laptop charge cable were not perfect but I consider that backup power option once I have a dedicated USB-C brick.
I will be sure to get another pinecil to put into my laptop bag. it makes me wonder if I got a USB-C-->USB-C cable if the laptop's C port could directly power the pinecil from battery.
When not in a workbench situation are there any neat tricks to safely cool the soldering tip?
I guess I have a cheap spiral soldering iron holder that I keep in my toolbox but I want a solution as advanced and portable as the pinecil.
Pinecil also works fine with Baseus BS-EU905 quick travel charger via USB-C output (PD@15V). Heating up to 320 Celsius within about 10 seconds.
awesome
(02-12-2021, 04:33 AM)biketool Wrote: While waiting for my pine power to arrive I noticed that the standard barrel tip power supply from all of the Asus laptops we have had from the last ~7-10 years are compatible with my pinecil.
That's great to know thank you! I've been trying to find out if my Acer laptop brick is compatible with the Pinecil. It's 19V / 65W with I believe a 5.5x1.7mm barrel?
[Image: IMG-0123.jpg]
Would it be safe to use a barrel jack adapter to 5.5x2.55mm for the Pinecil?
Thank you
Thank you
A guy I work with broke mine using a 5521 tip and trying to twist-force the connector(broke off the center pin) it is designed with a 5525 connector.
see below, I wont give you permission but you can read these datasheets which seem to be the closest to what I see and make your own decision
https://www.cuidevices.com/product/resou...2-5525.pdf
https://www.cuidevices.com/product/resource/pj-007.pdf
also read this thread
https://forum.pine64.org/showthread.php?tid=13237
Thank you
Thank you. I don't want to twist-force so looks like I need a 5517 to 5525 adapter. Finding one is proving difficult though!
Thank you
You could always get a 5525 barrel tip, cut the wrong size tip off, and solder the 5525 tip on.  Many come with a nice strain relief included so look for that
(05-04-2022, 05:34 AM)biketool Wrote: You could always get a 5525 barrel tip, cut the wrong size tip off, and solder the 5525 tip on.  Many come with a nice strain relief included so look for that
That power brick I still use for my (very old) laptop occasionally, but I think I've found an elegant solution! After an afternoon of searching I managed to find some adapter tips, so it'll go 5517 to 5521, then 5521 to 5525 barrel. Couldn't find a 5517 straight to 5525 unfortunately. Hoping it shouldn't be a problem! I do try and exercise caution when it comes to all things electricity Smile
Just by way of update, I now have the adapter tips which look like this:
[Image: IMG-0128.jpg]
So that's 5517 > 5521 > 5525. It may be the long way round but this way I can keep the charger intact for my laptop. May be useful for anyone else out there with an old 5517 Acer brick.
(05-21-2022, 05:56 AM)lozza_c Wrote: Just by way of update, I now have the adapter tips which look like this:
Just got my first Pinecil and wow, what a great device it is. Along with an ASUS laptop power supply, a Toshiba laptop power supply will also work, although a little shy on wattage, just 45 watts, 19V and 2.3A. but the tip is perfect and the cord is nice and soft and movable. I have also used it with an Anker 737 which is able to crank out 20V using an Anker USB C to USB C cable.
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 643 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 830 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,149 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 8,790 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 4,610 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 1,198 05-15-2025, 01:35 AM
Last Post: autumnharris
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 0 1,779 03-22-2025, 07:29 AM
Last Post: BigCarrotLeaf
  Pinecil constantly cutting out WroughtIron 1 2,667 01-16-2025, 02:20 AM
Last Post: D4veC4rter
Exclamation Pinecil is working with 5v but nothing else!! MizterPink 1 1,861 01-07-2025, 03:59 PM
Last Post: MizterPink
  Pinepower suitable for an s23 (and a pinecil) its_lieseeeee 0 1,431 12-09-2024, 01:41 PM
Last Post: its_lieseeeee
