Armbian and LibreELEC and AltLinux for Quartz64
#31
Libreelec Version 20220426. kernel 5.18-rc4 (rk356x)
Added support for different screen resolutions for rk356x.
ArmbianTV 20220428 with kernel 5.18-rc4 (edge) and 5.17.5 (current)
Libreelec 20220504. kernel 5.18-rc5
ArmbianTV 20220505 with kernel 5.18-rc5 (edge) and 5.17.5 (current)
AltLinux 20220505 kernel 5.17.5
no hdmi
kernel panics on rockchip usb2phy
memory speed is wrong
(05-12-2022, 12:33 PM)shaggy013 Wrote: no hdmi
Show the UART log and the full name of the image version.
LibreELEC-ARMv8.aarch64-11.0-devel-20220512120655-8bd19d9-rk3566-quartz64a
.log   putty.log (Size: 107.87 KB / Downloads: 396)
(05-13-2022, 05:17 AM)shaggy013 Wrote: LibreELEC-ARMv8.aarch64-11.0-devel-20220512120655-8bd19d9-rk3566-quartz64a
Now I checked the LE image - everything works. HDMI is working, video decodes with HW. there is no kernel panic, what you see are service messages, if there was a kernel panic, you would not be able to output DMESNG. And the memory speed is also fine, it is more than enough for the system to work (including for software decoding of the 1440p format). Check your monitor so that it meets the operating conditions of the main core (1080p).
hdmi > lvds adapter no hdmi
so flashed again moved board to tv
sony 4k etc tv no hdmi
plugged in and out cable nothing
Samsung 1080 tv no hdmi
frokm hdmi 1 cable to hdmi xxx no hdmi
well the dmesg triggers the kernel panic and reboots the device
Ambian: newest build i cant mount SSD disk via USB 3.0, on 2.0 ports works pretty well. Also cleaning and creating partition doesnt work on 3.0 Sad
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 16,355 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 1,968 07-30-2025, 07:19 AM
Last Post: pugzarecute
  USB on Quartz64 Zero litbulb 0 1,434 11-13-2024, 08:16 AM
Last Post: litbulb
  DietPi OS for Quartz64 MichaIng 47 51,983 08-08-2024, 07:42 AM
Last Post: ifreislich
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 82,215 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 4,960 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 3,918 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 5,011 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 10,191 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 3,677 07-21-2022, 01:08 PM
Last Post: Randomuser
