USB on Quartz64 Zero
I apologize if this post is against the rules.  I have some Quartz64 Zero boards and no matter what Linux image I use the USB port doesn't work.  The Android 13 sdcard image does have USB but the OS is unstable.  Does anyone know how to bring the USB port up?  I have console access via cp2102.
Which Linux image did you use? There does not seem to be any for the Quartz64 Zero, and the Quartz64 Model A device tree seems to have the USB issues on the Zero. I wanted to look into the device tree of the Android 13 image, but couldn't find sources, and am not keen to download the full 111 GiB SDK: https://forum.pine64.org/showthread.php?tid=20326
So if anyone knows whether/where there are browsable PINE64 Android sources, or has the SDK at hand to post the Quartz64 Zero device tree here, I might be able to derive one that works (including USB) with mainline Linux.
The Model A device tree mismatch is likely the whole problem — the Zero's USB wiring and PHY setup differ, so borrowing that DT won't bring the port up cleanly. On the browsable-sources question, the Android tree is usually split across a kernel repo plus a separate device repo, so you may not need the full SDK to find the Quartz64 Zero DTS; worth checking whether Pine64 mirrors the kernel and device trees individually rather than only as a monolithic SDK download. If you can get even the USB node out of the Android DT, diffing it against mainline would show what's missing.
  DietPi OS for Quartz64 MichaIng 48 65,096 07-22-2026, 01:52 PM
Last Post: MichaIng
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 19,119 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,722 07-30-2025, 07:19 AM
Last Post: pugzarecute
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 194,414 03-23-2025, 01:10 AM
Last Post: balbes150
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 94,948 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 6,223 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 5,002 07-20-2023, 10:44 PM
Last Post: beepy
  crux-arm Quartz64 RK3566 (aarch64) mara 5 11,763 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 4,390 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 60,693 03-17-2022, 06:29 AM
