How does CPU frequency scaling work on the Quartz64
I was working on linux on the Radxa Zero 3W. Unfortunately, I am having  some issues getting CPUFreq up. It complains about  missing OPP tables.
While I dont ask for help with fixing the Zero 3W, since this will be offtopic, I would just like to know how the CPUFreq  system  works on Quartz64.
Does CPU Frequency scaling work on the Quartz64(especially with mainline 6.12.35)?
Does it use the mainline cpufreq-dt driver or does it require some rockchip patches?
Are the OPP tables supplied by the DTB or is there something like rockchip-opp to supply them?
Thank you.
  USB on Quartz64 Zero litbulb 2 3,054 11-09-2026, 01:33 PM
Last Post: elizabethtaylor
  DietPi OS for Quartz64 MichaIng 48 65,187 07-22-2026, 01:52 PM
Last Post: MichaIng
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 19,135 03-07-2026, 04:21 PM
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 194,555 03-23-2025, 01:10 AM
Last Post: balbes150
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 95,002 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 6,231 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 5,016 07-20-2023, 10:44 PM
Last Post: beepy
  crux-arm Quartz64 RK3566 (aarch64) mara 5 11,782 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 4,393 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 60,730 03-17-2022, 06:29 AM
