Pinebook Pro bricked after flashing eMMC
I flashed Manjaro-ARM-kde-plasma-pbpro-21.12 to eMMC from a SD boot as described at https://wiki.pine64.org/wiki/NOOB#Flashi..._a_SD_Boot.
After rebooting, my Pinebook Pro got stuck at the Manjaro logo with the spinning circle.
When I press the Esc key, I see the following message, but the shell does not recognize any keystrokes:
:: running hook [udev] :: Triggering uevents... :: running hook [plymouth] :: performing fsck on '/dev/mmcblk2p2' ROOT_MNJRO: The filesystem size (according to the superblock) is 15205335 blocks The physical size of the device is 1763287 blocks Either the superblock or the partition table is likely to be corrupt! ROOT_MNJRO: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.         (i.e., without -a or -p options) ERROR: Bailing out. Run 'fsck /dev/mmcblkp2' manually ********** FILESYSTEM CHECK FAILED ********** *                                           * *  Please run fsck manually. After leaving  * *  this maintance shell, the system will    * *  reboot automatically.                    * *                                           * ********************************************* sh: can't access tty; job control turned off [rootfs /]#
I tried booting from the SD card again, but it does not seem to work as I end up with the same message as above.
Please help!
  Updated Pinebook Pro? tantamount 2 2,529 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,306 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,909 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,576 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,008 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 10,938 02-09-2026, 12:50 AM
Last Post: Anthona
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,255 12-18-2025, 01:05 AM
Last Post: qingss0
  Pinebook Pro for sale rfm83 0 2,089 11-08-2025, 09:22 AM
Last Post: rfm83
  swap eMMC advice jceaser 2 2,557 10-23-2025, 09:59 PM
  Need new eMMC Karsten1 2 4,682 10-23-2025, 09:38 AM
Last Post: jceaser
