PIneTime reconnect script
Hey folks, I was having issues with my PineTime reconnecting to my PInephone after waking up from suspend. I noticed when I would cycle bluetooth on and off eventually it would re-connect.
Arch wiki showed me a neat way to run a script on wake every time. I started playing with that and got a decent working reconnect script. I have tested it for a few days and now am curious if it will work well for other people using the PineTime with the PInePhone
setup:
PinePhone 3gb running Manjaro-Arm
PineTime running InfiniTime 1.7.
Amazfish as the companion app
Here is the github with instruction and the script that will take your PineTime BT mac address and make a small shell script for connecting and a systemd service to fire that script any time the PInePhone wakes from suspend. It is enabled to start on boot and requires a restart of both PT and PP after the script is done.
https://github.com/kmsgli/pt-connect/
I recognize this if probably not the best way to fix my reconnect issues but it seems to work for now and I am certainly open to suggestions if anyone thinks there is a better way to do this.
  Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 3 5,407 06-06-2026, 03:33 PM
Last Post: oscar-gardiazabal
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 5,266 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 4,428 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 11,384 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 6,390 07-30-2025, 11:44 PM
Last Post: karthick
  PineTime charging issues - connecting pins black gsoundsgood 2 4,602 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 7,488 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 11,785 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 7,599 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 3,004 01-31-2024, 11:57 AM
Last Post: tynstar
