Installing r2kaw and Tow-Boot to the SPI
(12-18-2024, 07:01 PM)ethical_haquer Wrote: ...
What is the camera situation like for the PPP with Arch? On pmOS edge it got a lot better with the kernel update, but the back camera stops working after a suspend. And you mention you have pmOS on the PP, since it's so under-powered - does Arch use more power or something? TIA.
Megapixels is installed for PPP/arch/SXMO but doesn't start at all - missing pinephone-pro.ini
I am not particularly bothered - I do recall some chatter about an alternative camera application coming (maybe, someday ...) Mostly if I am clicking a shutter it is wildlife and lots and lots of optical zoom is my toy.
On paper pmOS is leaner (more minimalist) than arch. I can't say I really notice it though. I think at some stage I timed booting to the same point and pmOS was a bit faster. But really for my usage fairly academic: on SXMO I tend to open Telegram in 1 window, Firefox in a second and LiFeRea in a 3rd, leaving a 4th for geary or terminal or whatever. In practice Firefox slugs most resources (CPU, memory) when it gets a couple of tabs open and and marginal OS gains are trumped. But once all the applications are loaded the PP is pretty usable.
Overall I am pretty hitched to arch as it works for my desktop and I have learned to compile the applications (gnucash, fotocx) that may be in Ubuntu or Debian repositories but not in arch. But pretty sure I would have a bit to learn if I tried to do the same thing on pmOS. Also have arch on my partner's laptop.
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 9,707 02-25-2025, 08:27 AM
  tow-boot installation problem techariah 4 8,200 12-04-2024, 10:32 AM
Last Post: zetabeta
  How can boot from MicroSD after replacement of the main board u-kidjp 6 6,616 11-08-2024, 09:14 PM
  tow-boot, just bought pinephone pro stratofall 4 5,269 07-30-2024, 03:43 PM
Last Post: stratofall
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 105,073 02-13-2024, 02:54 PM
Last Post: fxc
Brick Recovery without Tow Boot b34ux 10 11,587 02-02-2024, 07:07 PM
Last Post: reky
  What to do if your PinePhone Pro does not boot fxc 19 47,140 09-10-2023, 03:19 AM
Last Post: fxc
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 6,693 02-18-2023, 06:14 PM
Last Post: fxc
  create tow boot .img fox95 6 10,274 10-21-2022, 11:40 AM
Last Post: fox95
  No display on early boot after Manjaro update robocone 0 2,417 07-07-2022, 05:47 AM
Last Post: robocone
