Pinetab2 not starting
(06-17-2024, 06:40 PM)angeloweb Wrote:
(06-03-2024, 01:43 PM)tllim Wrote:
(06-02-2024, 04:11 PM)angeloweb Wrote: My Pinetab2 does not appear to be accepting power. It worked for months, then, after being untouched (while plugged in) for a couple of weeks, it wouldn't work right. Even with power plugged in the power-port, won't start.
Shortly before the battery totally drained, it would try to power on for a couple of seconds, then turn off.
Tried multiple cables & charging devices. I figure that even if the battery is having issues, with being plugged in it would still power up. Maybe trouble with the usb-c port or something else? Any ideas?
Using accompanied UART dongle and check whether their is console message.
Tried the uart, cannot get it to boot.
I have a similar problem with my Pinetab2. The I've tried several charging cables, and I'm plugging into the USB-C/PD port, but it no longer will turn on after months of working perfectly. I obtained a UART, but this is not helpful if the Pinetab2 does not turn on at all. It is as if the battery died. If anyone has a suggestion I would welcome it, as I saw in another post that Pine64 has no intention of selling replacement batteries for the PineTab2. I would hate to think that this is bricked already.
(03-06-2025, 04:08 PM)snowka Wrote: I have a similar problem with my Pinetab2. The I've tried several charging cables, and I'm plugging into the USB-C/PD port, but it no longer will turn on after months of working perfectly. I obtained a UART, but this is not helpful if the Pinetab2 does not turn on at all. It is as if the battery died. If anyone has a suggestion I would welcome it, as I saw in another post that Pine64 has no intention of selling replacement batteries for the PineTab2. I would hate to think that this is bricked already.
My pinetab2 didn't start. The screen was always black. I charged it one night.
I created an sdcard with latest image (https://pine64.org/documentation/PineTab...tructions/). I inserted it in the micro sdcard port, pressed the power button and the screen turned on. I reinstalled the whole system. It erases all data but now it works again.
this is a universal Li-ion and Lipo battery issue, the charging circuit decides your battery is undervolted and is now perma-dead.
Best case is to have a Li-ion charging circuit board fed by USB power and let the cell slow charge for a few hours shaped by the charging board's IC.
For emergency purposes though a Li-Ion cell is rated to take 5v just strip-off a USB cable and clip/solder into the battery circuit(verify polarity via multimeter to avoid reversing and ruining/exploding cell) and run 5v for a few minutes, reassemble and boot with power USB cable attached to continue charging; repeat if the cell needs more charging to get to booting voltage(between 3v and 3.5 I think).
  PineTab2 spec for ddr and rth 0 3,402 12-09-2025, 08:28 PM
Last Post: rth
  What is the state of the PineTab2 today? Arcikks 2 4,846 12-04-2024, 08:30 PM
Last Post: dachalife
  pinetab2 hardware is not very good lmartin 13 18,065 07-30-2024, 08:50 AM
Last Post: Piotr Bujakowski
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 4,521 03-16-2024, 11:56 AM
Last Post: scottgr
  Pinetab2 screen removal Corconegre 5 7,831 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 6,231 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 3,156 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 3,075 10-14-2023, 05:48 PM
Last Post: lockedpotato
  pinetab2 booting when adapter connected Ome Ko 16 17,292 09-15-2023, 11:45 PM
Last Post: Ome Ko
  SOLVED: New PineTab2 not booting properly. SECONDARY PROBLEM SOLVED: Not updating bacon_dude 6 10,303 09-06-2023, 07:43 PM
Last Post: bacon_dude
