An unofficial Debian Installer for Pinebook Pro
Yes, the included uboot doesn't support compressed kernels. How long did you wait for the boot to complete? One of the issues danielt mentioned patching was to avoid scheduling anything on the slower cores until the cpu frequency manager is running; u-boot apparently hands execution over to the core with them scaled down to the point where booting takes minutes rather than seconds.
Regarding cpus.
Can anyone point me to a working method of bringing big cores back online manually ?
If I do ”echo 1 >” I get input/output error.
Hey @danielt thanks for making this installer and for recently adding 'do_shell' as well.  It makes it easier to chroot in and run tasksel.  I select the bare minimum when the initial installer runs so I can add my apt-cacher-ng proxy information later and run tasksel.  That way it pulls all the packages from my local cache.
I added it to the installer as a mirror argument to debootstrap but then it wouldn't pull down the kernel from the suse link.  Something with my apt-cacher-ng not liking the url that I haven't looked into.
Yeah I shouldn't be installing over and over but have been running into a bunch of stuff that dumps core while trying to find a working firefox. Sad
And when it is really broken it is somewhat easier to just reinstall.
(01-25-2020, 05:23 PM)gillham Wrote: Be careful upgrading to unstable packages as I installed firefox from unstable (which works) but later did a 'dist-upgrade' that installed a number of new packages from unstable.  Then gdm3 wouldn't come up due to a segv somewhere.  I tested a few times and figured out a number of packages that needed to be held back.  I don't have the list handy right now, but I can post it later.  Basically it seems to me there is a compiler problem affecting us.
EDIT:  FWIW, here are the packages from unstable I had to hold to keep GDM3 from core dumping.  There might be more, this is just what I ran into as mentioned above.
echo "libgjs0g hold" | dpkg --set-selections
echo "libgirepository-1.0-1 hold" | dpkg --set-selections
echo "libglib2.0-0 hold" | dpkg --set-selections
echo "libglib2.0-bin hold" | dpkg --set-selections
echo "libwayland-client0 hold" | dpkg --set-selections
echo "libwayland-server0 hold" | dpkg --set-selections
you need to pin apt preferences and set unstable and experimental packages to lower than 100 priority.
I use 2 for experimental and 3 for unstable just to confirm the configs work.
@danielt is your kernel config shared anywhere here? I'd like to repro it exactly, with the addition to run armhf binaries when making.
Thanks!
— Jeremiah Cornelius
pass ARCH=armhf to the installer to build a complete armhf system
the kernel is arm64 and the config is in /boot on your system already.
could post the config later tonight if you are on a diff system...
Chromium has migrated finally to testing and can be installed with apt. Unfortunately it has no HW acceleration for video for some reason. It currently pegs all cores playing a 360px video on Youtube and even then the frame rate is low.
(01-25-2020, 05:41 PM)Der Geist der Maschine Wrote: My kernel was half the size of Daniel's kernel. That made me realize that mine was compressed while his was not.
I assume that's why uboot refused to boot it and moved on to the next kernel in the extlinux.conf list.
Now that I uncompressed my kernel, a boot ends up in a black screen. I assume Daniel put some magic into his kernel deb.
Sort of. There is an environment variable that controls which kernel image goes into the deb and it needs to be set to point to an uncompressed image (as it happens I *did* have to add some code for get KBUILD_IMAGE to work on the openbuildservice but it is not needed for local builds).
Try something like:
make  KBUILD_IMAGE=arch/arm64/boot/Image bindeb-pkg
Note that if you have already built a kernel then you don't have to build the kernel again, you can simply uncompress it:
sudo mv vmlinuz-$ver vmlinuz-$ver.gz
sudo gunzip vmlinuz-$ver.gz
(01-26-2020, 06:24 PM)Jeremiah Cornelius Wrote: @danielt is your kernel config shared anywhere here? I'd like to repro it exactly, with the addition to run armhf binaries when making.
Thanks!
Depends how exact you want to be!
As mentioned in a previous post https://forum.pine64.org/showthread.php?...7#pid56887 I don't want my kernel tree to distract attention from Thomas' since it simply fragments the community (that post also shows how I build the kernel).
However neither do I want to be secretive, especially since the kernel config is included in the kernel itself (try: gunzip -c /proc/kconfig.gz ). Should you ever need it the exact sources can be found on the openbuildservice: https://build.opensuse.org/package/show/...elthompson .
(01-26-2020, 04:03 AM)as400 Wrote: Regarding cpus.
Big cores are brought back online (as root) with:
echo 1 > /sys/devices/system/cpu/cpu4/online
echo 1 > /sys/devices/system/cpu/cpu5/online
If you get input/output errors when running the above as root then check the dmesg log to see if there are any extra details (especially if you are running a self-compiled kernel).
(01-27-2020, 03:18 AM)danielt Wrote: Big cores are brought back online (as root) with:
If I do "echo 1 > /sys/devices/system/cpu/cpu4/online" I get input/output error.
Dmesg shows the same - just "input/output error" - nothing else.
I use Manjaro 5.5 kernel.
(01-27-2020, 04:18 AM)as400 Wrote: If I do "echo 1 > /sys/devices/system/cpu/cpu4/online" I get input/output error.
Can you explain in more detail what you mean by "shows the same" (perhaps post the dmesg output to a pastebin or github gist)?
  Boot Order in Pinebook Pro food 12 18,339 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,214 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,067 08-09-2025, 06:53 AM
Last Post: Sb2024
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,479 06-26-2025, 09:20 PM
Last Post: reukiodo
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,428 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 121,416 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,633 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,279 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 17,353 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,172 12-13-2023, 07:22 PM
Last Post: trillobite
