Will purchasing an NVMe SSD noticably improve performance
#20
I do not have a SSD adapter that I can use yet, so I tested only on the eMMC 128G and a class 10 SD device
mmcblk2 is the eMMC and mmcblk1 is the SD card. You can ignore the HDD mentions, I had to adapt a tool that is used for another tests.
WARNING: you have disable RPM check, tool will fail if prerequisites listed on the README file are not installed
INFO: checking devices JSON information
INFO: mmcblk2p1 drive in the JSON file seems to be correctly populated
INFO: mmcblk1p1 drive in the JSON file seems to be correctly populated
INFO: checking devices status
OK: mmcblk2p1 defined by you as HDD is in the system as block device
OK: mmcblk1p1 defined by you as HDD is in the system as block device
INFO: Going to start test randread with blocksize of 128k on device mmcblk2p1 please be patient
Jobs: 1 (f=1): [r(1)][100.0%][r=150MiB/s][r=1200 IOPS][eta 00m:00s]
INFO: Completed test randread with blocksize of 128k on device mmcblk2p1
INFO: Going to start test randread with blocksize of 128k on device mmcblk1p1 please be patient
Jobs: 1 (f=1): [r(1)][100.0%][r=54.4MiB/s][r=435 IOPS][eta 00m:00s]
INFO: Completed test randread with blocksize of 128k on device mmcblk1p1
INFO: All tests completed
OK: drive mmcblk2p1 with IO drop[s] of 0.0 passes the IO drops KPI of 0 for test mmcblk2p1_randread_128k
OK: drive mmcblk2p1 with minimum IOPS of 1172.0 passes the HDD IOPS KPI of 55.0 for test mmcblk2p1_randread_128k
OK: drive mmcblk2p1 with maximum latency of 26.0 passes the HDD latency KPI of 300.0 for test mmcblk2p1_randread_128k
OK: drive mmcblk2p1 with mean IOPS of 1210.25 passes the HDD IOPS KPI of 110.0 for test mmcblk2p1_randread_128k
OK: drive mmcblk2p1 with mean latency of 13.14 passes the HDD latency KPI of 15.0 for test mmcblk2p1_randread_128k
OK: drive mmcblk1p1 with IO drop[s] of 0.0 passes the IO drops KPI of 0 for test mmcblk1p1_randread_128k
OK: drive mmcblk1p1 with minimum IOPS of 432.0 passes the HDD IOPS KPI of 55.0 for test mmcblk1p1_randread_128k
OK: drive mmcblk1p1 with maximum latency of 262.0 passes the HDD latency KPI of 300.0 for test mmcblk1p1_randread_128k
OK: drive mmcblk1p1 with mean IOPS of 436.63 passes the HDD IOPS KPI of 110.0 for test mmcblk1p1_randread_128k
ERROR: drive mmcblk1p1 with mean latency of 36.61 does not pass the HDD latency KPI of 15.0 for test mmcblk1p1_randread_128k
ERROR: drive type HDD has IOPS percentage difference of 63.92 which does not pass the KPI of 10 for IOPS difference for same drive type for test mmcblk1p1_randread_128k
OK: drive type HDD has latency percentage difference of 64.11 which does not pass the KPI of 10 for latency difference for same drive type for test mmcblk1p1_randread_128k
INFO: drive type SSD was not tested, so no percentage difference applies for test mmcblk1p1_randread_128k
INFO: drive type NVME was not tested, so no percentage difference applies for test mmcblk1p1_randread_128k
ERROR: the difference between drives is not acceptable by the KPIs
Summary of this run:
FAILURE: All drives do not fulfill the KPIs. You *cannot* continue with the next steps
ERROR: The settings of this test run do not qualify as a valid run to check thr KPIs. You *cannot* continue with the next steps
So it seems that for randread 128K the eMMC has x3 times IOPS and almost 3 times less latency, so no brainer to get a eMMC and use it as primary device. While numbers are far from what I would expect from a SSD I guess the electrical factor vs a SSD is to be measured too. When I get an adpater I can use I will do the same test vs a device there .
RE: Will purchasing an NVMe SSD noticably improve performance - by bolinches - 11-14-2019, 03:29 PM
  New Working nVME gilwood 0 247 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,586 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,858 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,555 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,946 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,885 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,919 12-10-2021, 07:47 PM
Last Post: josmo
  NVMe SSD testing methodology halogen 1 2,663 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,849 07-09-2021, 08:45 PM
Last Post: moonwalkers
  nvme drive disappears after about an hour of uptime codebreaker 25 32,471 02-09-2021, 11:32 PM
Last Post: dsimic
