Pro NVMe adapter Does not fit ! ?
#30
(11-01-2019, 08:55 AM)belfastraven Wrote:
(10-28-2019, 11:10 PM)bcnaz Wrote: CampGareth :
 Thanks for your (Block diagram style) description of the process,  I think that makes it easier to comprehend what needs to happen.
 but actually writing the code for each device to communicate with the next  I believe is slightly more complex.  ?  ?
 Arwen and z4v4l  are having a more detailed discussion on this,   in the thread  "u-boot location on the disk"
As I said earlier,  I started this particular thread to discuss physically fitting the NVMe and adapter into the Pinebook Pro laptop.
> That issue has been solved by the Pine staff.<
The thread " u-boot location on disk"  will be a better place to discuss the firmware/software issues.
Has any one gotten the "fixed bits and pieces"  for the NVME adapter.?  I've had the adapter  for weeks.  I ordered it with the other bits and pieces in August.  I just got the PBPro and would really like to install the drive....
I have not gotten the bits and pieces.  However:
I was one of the 15 who didn't get the original delivery for the first batch.  I had also ordered the adapter at the same time, in the same shipment, so that arrived yesterday along with the laptop.  Since the issue has been fixed between when I ordered the PBP and when the unit (including the adapter) left the factory, it was unclear as to whether the adapter I received was the new version or the old version.  I asked Luke this, and he said that I should have the new version.  I have not yet confirmed this by physically installing the adapter.  I don't know what the new adapter looks like compared to the old one, but what I received is just the backplate, adapter cable, and screws.
I will be testing tonight or tomorrow.
Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-04-2019, 03:03 PM
RE: Pro NVMe adapter Does not fit ! ? - by hdk - 10-05-2019, 01:00 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-21-2019, 09:38 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-05-2019, 04:02 AM
RE: Pro NVMe adapter Does not fit ! ? - by hdk - 10-05-2019, 04:47 AM
RE: Pro NVMe adapter Does not fit ! ? - by hdk - 10-05-2019, 07:25 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-05-2019, 05:25 AM
RE: Pro NVMe adapter Does not fit ! ? - by hdk - 10-05-2019, 06:03 AM
RE: Pro NVMe adapter Does not fit ! ? - by hdk - 10-05-2019, 08:49 AM
RE: Pro NVMe adapter Does not fit ! ? - by ndp - 10-21-2019, 04:16 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-21-2019, 06:37 AM
RE: Pro NVMe adapter Does not fit ! ? - by Luke - 10-23-2019, 05:59 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-26-2019, 08:06 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-27-2019, 05:35 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-27-2019, 07:05 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-28-2019, 11:37 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-27-2019, 07:25 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 10-28-2019, 11:10 PM
RE: Pro NVMe adapter Does not fit ! ? - by binarian - 11-01-2019, 09:13 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 11-01-2019, 09:07 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 11-01-2019, 09:41 AM
RE: Pro NVMe adapter Does not fit ! ? - by Luke - 11-01-2019, 09:45 AM
RE: Pro NVMe adapter Does not fit ! ? - by nakato - 11-01-2019, 08:22 PM
RE: Pro NVMe adapter Does not fit ! ? - by sundog - 11-02-2019, 10:57 AM
RE: Pro NVMe adapter Does not fit ! ? - by Luke - 11-02-2019, 11:06 AM
RE: Pro NVMe adapter Does not fit ! ? - by sundog - 11-02-2019, 11:13 AM
RE: Pro NVMe adapter Does not fit ! ? - by Arwen - 11-02-2019, 11:23 AM
RE: Pro NVMe adapter Does not fit ! ? - by mdmbc - 11-03-2019, 06:55 PM
RE: Pro NVMe adapter Does not fit ! ? - by hdk - 11-11-2019, 05:49 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 11-12-2019, 08:39 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 11-22-2019, 12:45 PM
RE: Pro NVMe adapter Does not fit ! ? - by tllim - 11-25-2019, 01:04 AM
RE: Pro NVMe adapter Does not fit ! ? - by Thra11 - 11-25-2019, 10:19 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 12-03-2019, 02:47 PM
RE: Pro NVMe adapter Does not fit ! ? - by c6Q$! - 12-14-2019, 05:35 AM
RE: Pro NVMe adapter Does not fit ! ? - by zaius - 12-16-2019, 12:23 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 04-07-2020, 05:15 PM
RE: Pro NVMe adapter Does not fit ! ? - by Arwen - 12-16-2019, 05:51 PM
RE: Pro NVMe adapter Does not fit ! ? - by zaius - 12-16-2019, 06:54 PM
RE: Pro NVMe adapter Does not fit ! ? - by Arwen - 12-17-2019, 05:31 AM
RE: Pro NVMe adapter Does not fit ! ? - by zaius - 12-17-2019, 02:42 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 01-26-2020, 06:55 PM
RE: Pro NVMe adapter Does not fit ! ? - by zaius - 02-13-2020, 12:32 PM
RE: Pro NVMe adapter Does not fit ! ? - by zaius - 03-11-2020, 12:31 PM
RE: Pro NVMe adapter Does not fit ! ? - by tllim - 03-21-2020, 01:07 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 03-21-2020, 06:52 PM
RE: Pro NVMe adapter Does not fit ! ? - by tllim - 03-21-2020, 08:36 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 03-21-2020, 10:10 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 03-29-2020, 10:42 PM
RE: Pro NVMe adapter Does not fit ! ? - by Kaythe - 03-30-2020, 01:02 AM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 04-01-2020, 01:28 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 04-04-2020, 08:29 PM
RE: Pro NVMe adapter Does not fit ! ? - by bcnaz - 04-07-2020, 04:02 PM
RE: Pro NVMe adapter Does not fit ! ? - by josmo - 04-11-2020, 12:10 AM
RE: Pro NVMe adapter Does not fit ! ? - by Arwen - 04-14-2020, 10:41 AM
RE: Pro NVMe adapter Does not fit ! ? - by Arwen - 04-15-2020, 01:59 PM
  New Working nVME gilwood 0 223 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,548 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,818 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,424 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,918 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,867 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,759 12-10-2021, 07:47 PM
Last Post: josmo
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,403 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  NVMe SSD testing methodology halogen 1 2,644 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,800 07-09-2021, 08:45 PM
Last Post: moonwalkers
