Unable to use PineBook anymore
Hi all,
I have got a PineBook 11", one of the older ones. It came with Ubuntu + XFce preinstalled. I've been using successfully it for a few years now.
Due to the fact that the HDMI port was not working at all (I was told that it would not work with that OS), I decided to burn another image.
So, I connected the power unit to the PineBook, and started the process. I did not worry about the battery anymore, I just assumed it would recharge. I tried another image successfully, but I removed the card before powering off the machine (erroneously thinking that it was working off RAM). So I had to start all over again, since the SD Card was now corrupted.
But then I experienced a problem, when trying to boot from the new image the machine would turn off itself. At the beginning, I though the SD Card was the problem, so I tried another OS, with the same result.
Finally I realized that the problem was the battery. Though still plugged, the PineBook was not lighting the yellow/green led at the side of the power connector, and with the SD Card out, now it was showing the image of an empty battery and turning off itself.
The situation now is that when unplugged, it does nothing pressing the on/off button. If plugged, now the on/off led light is turned on, and after a couple of seconds it turns off, and then on again, and so on...
I have tried to leave it plugged for a long time, to leave it unplugged for a long time... to no avail.
Any hint?
Thanks.
Unable to use PineBook anymore - by baltasarq - 07-23-2019, 08:23 AM
RE: Unable to use PineBook anymore - by tophneal - 07-23-2019, 09:48 AM
RE: Unable to use PineBook anymore - by baltasarq - 07-23-2019, 11:41 AM
RE: Unable to use PineBook anymore - by neilman - 07-23-2019, 12:24 PM
RE: Unable to use PineBook anymore - by AYeomans - 07-23-2019, 01:17 PM
RE: Unable to use PineBook anymore - by baltasarq - 07-25-2019, 12:01 PM
RE: Unable to use PineBook anymore - by neilman - 07-25-2019, 12:13 PM
RE: Unable to use PineBook anymore - by baltasarq - 07-25-2019, 01:22 PM
RE: Unable to use PineBook anymore - by pfeerick - 07-26-2019, 02:24 AM
RE: Unable to use PineBook anymore - by baltasarq - 07-26-2019, 03:49 AM
RE: Unable to use PineBook anymore - by pfeerick - 07-26-2019, 09:41 PM
RE: Unable to use PineBook anymore - by Dbh12 - 07-27-2019, 08:03 PM
  Not booting anymore from SD oloturia 0 546 09-29-2023, 10:18 AM
Last Post: oloturia
  Dead Pinebook - fix it or spare parts? oloturia 2 2,342 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 1,028 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,402 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 13,228 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 1,046 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,681 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,751 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 7,943 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,923 12-07-2020, 04:02 PM
Last Post: SanjevR
