some questions regarding the pinebook
(07-16-2017, 09:56 AM)schepers_cp Wrote: hi all , i'm new here and applied for the BTO of the 14" pinebook.
at first i thouhg the ""BTO" meant i can customize some things, but then i saw the product page in the store, which explains the term better than the bto page itself ^^;
i do have some questions about the pinebook
1: why is is so cheap in comparision to the olimex open source laptop? Big Grin
2: is there any upgrade path for the mainboard in the future, by which i only need to swap it and plug the emmc module in?
2-1: if so, what will those specs be? (i hope for >= 4gb ram, extra storage options, like a second emmc slot or a sata 3 or m.2 slot)
3: can there be a bigger battery in the unit, as i saw on google images that the insides between the 2 pcb's is unused space.
4: what is the sound quality like? if it is 'meh' , then i would sugggest for a newer revision the have a pair of high note speakers pointing out at the back of the system, like between the 2 hinges for the display (i did a similar mod to a el cheapo yepo 737s and the sound sounded waaay fuller, even pleasant for such a thin laptop!)
5: will there ever be a usb type c connector on a newer revision of the laptop?
6: would be fun to have an internal usb 2 port as well, for a usb to sata hdd for the lose space in the laptop
7: is the headphone jack also a mic in (2-in-1 solution?)
8: what are the thermals under load right now? does the cpu throttle? and what is the TDP of the SOC in watts peak?
9: is there a possibility of extra cooling by adding a flat copper plat or something?
10: what is the bottom panel made of? i hope aluminium, as my yepo 737s had that, and it acted as a cooling plate for the intel atom with a TDP of roughly 6W peak (2w average SDP (scenario design power))
11: does it run u-boot or some other bootloader?
12: what's the maximum battery lifespan on the default OS, at 50% brightness of the lcd, while having firefox with a youtube video running? (at the refernce 360p)
13: if i place a BTO request like right now, what will the expected waiting time be? (so i know around what period i can pay)
1. I have no idea. I saw the Olimex lappy at FOSDEM 17 in person and didn't see anything that would explain the price tag.
2. yes
2-1. no clue, but there is some speculation that A63 may be used for a future mainboard
3. The battery is large already - 7-10hrs of battery life, depending on what you are doing
4. meh
5.no clue - doubt it as USB type c is expensive
6. There is an internal USB 2.0 hub, I belive one USB 2.0 port is left open (dont quote me on this).
7. Will have to check withi someone more knowledgable Wink
8. Does throttle a bit under generic benchmarks load (past 80*C) - but rarely if ever in realistic use
9. The cooling is sufficient as is
10. the entire laptop is plastic
11. uboot
12. max ? - Id say close to 7-8hrs or so hrs
13. No clue
RE: some questions regarding the pinebook - by Luke - 07-16-2017, 10:10 AM
  Dead Pinebook - fix it or spare parts? oloturia 2 2,299 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 992 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,345 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 13,019 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 1,025 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,659 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,689 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 7,854 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,805 12-07-2020, 04:02 PM
Last Post: SanjevR
  TOR Browser on the Pinebook Pro jay3gg 0 3,033 11-16-2020, 01:25 AM
Last Post: jay3gg
