Pinebook's battery flat on arrival
(08-29-2017, 05:32 AM)MarkHaysHarris777 Wrote:
(08-29-2017, 04:53 AM)p3p1 Wrote:
(08-28-2017, 05:08 AM)MarkHaysHarris777 Wrote:
(08-28-2017, 03:46 AM)p3p1 Wrote: Since I bought my Pinebook I used it for a few times. After a day of use with the battery, I turned it off and now when I try to turn it on I have red battery icon. I followed the procedure 2+ hours (one night) of charging, removed and reinserted the power cables (12 times) and charging for another 1-2hrs, but still no boot. Someone can help me? The battery is gone?
No, the battery is not gone;  however, the PMIC "believes" that its gone !
...  you need to open the pinebook up (yes, I'm serious, ten tiny screws, then pop the bottom cover off ).
Carefully unplug the battery with the unit power adapter plugged in;  count 5, plug it back in  (wait a few minutes)
^  Repeat
Sometimes you have to repeat that many times;  what you'll be doing is "shocking" the battery UP to about 3.5 - 3.6 vots... then, the PMIC will "see" it and start charging.
The cause of this is that when you shutdown the system halted, but the unit didn't actually power off -- known problem.  If the unit does not power off, force it off with a very long press 12 seconds of the power button.  If the battery runs all the way flat, you'll be right back here again !
Also, to ensure that the unit more reliably powers off, when you shutdown do so by pressing the power buttom to pull up the shutdown dialogue instead of selecting shutdown from the menubar, or elsewhere.
Blush
I did the procedure almost 20+ times but still red battery icon. Just to recap:
1) power supply should be plugged
2) remove the battery connector (in attached picture), count 5, re-plug it.
3) wait 3+ min and turn on the pinebook
is it right?
Can I do something else? I noted a small battery pads close to battery connector can I use it in some way?
no, not quite.
Try:
1) power should be plugged
2) remove the batter connector  ( count 5 )
3) plug battery connector back in and wait 10-20 minutes !
4) repeat if necessary
some people have had to do this many many many times;
Finally it's working after 23 times. I have a question the right ways to shutdown are the shutdown dialog or press power button (physical button) for 12 sec: is there a way via terminal ?
Pinebook's battery flat on arrival - by Luke - 06-26-2017, 10:52 AM
RE: Pinebook's battery flat on arrival - by Erik - 06-26-2017, 01:29 PM
RE: Pinebook's battery flat on arrival - by p3p1 - 08-28-2017, 03:46 AM
RE: Pinebook's battery flat on arrival - by p3p1 - 08-29-2017, 04:53 AM
RE: Pinebook's battery flat on arrival - by p3p1 - 08-29-2017, 05:17 PM
RE: Pinebook's battery flat on arrival - by p3p1 - 08-30-2017, 04:20 PM
RE: Pinebook's battery flat on arrival - by dejan - 03-19-2018, 08:33 AM
RE: Pinebook's battery flat on arrival - by Luke - 03-19-2018, 09:04 AM
RE: Pinebook's battery flat on arrival - by tllim - 10-30-2019, 07:49 PM
  Dead Pinebook - fix it or spare parts? oloturia 2 2,301 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 996 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,348 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 13,046 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 1,026 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,661 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,696 08-18-2021, 11:01 PM
Last Post: Corkonian
  Battery life unrealb2 4 5,704 08-01-2021, 12:26 AM
Last Post: unrealb2
  new pinebook help ron_burgundy 5 7,860 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,819 12-07-2020, 04:02 PM
Last Post: SanjevR
