Pinebook's battery flat on arrival
(08-28-2017, 05:08 AM)MarkHaysHarris777 Wrote:
(08-28-2017, 03:46 AM)p3p1 Wrote: Since I bought my Pinebook I used it for a few times. After a day of use with the battery, I turned it off and now when I try to turn it on I have red battery icon. I followed the procedure 2+ hours (one night) of charging, removed and reinserted the power cables (12 times) and charging for another 1-2hrs, but still no boot. Someone can help me? The battery is gone?
No, the battery is not gone;  however, the PMIC "believes" that its gone !
...  you need to open the pinebook up (yes, I'm serious, ten tiny screws, then pop the bottom cover off ).
Carefully unplug the battery with the unit power adapter plugged in;  count 5, plug it back in  (wait a few minutes)
^  Repeat
Sometimes you have to repeat that many times;  what you'll be doing is "shocking" the battery UP to about 3.5 - 3.6 vots... then, the PMIC will "see" it and start charging.
The cause of this is that when you shutdown the system halted, but the unit didn't actually power off -- known problem.  If the unit does not power off, force it off with a very long press 12 seconds of the power button.  If the battery runs all the way flat, you'll be right back here again !
Also, to ensure that the unit more reliably powers off, when you shutdown do so by pressing the power buttom to pull up the shutdown dialogue instead of selecting shutdown from the menubar, or elsewhere.
Blush
I did the procedure almost 20+ times but still red battery icon. Just to recap:
1) power supply should be plugged
2) remove the battery connector (in attached picture), count 5, re-plug it.
3) wait 3+ min and turn on the pinebook
is it right?
Can I do something else? I noted a small battery pads close to battery connector can I use it in some way?
Pinebook's battery flat on arrival - by Luke - 06-26-2017, 10:52 AM
RE: Pinebook's battery flat on arrival - by Erik - 06-26-2017, 01:29 PM
RE: Pinebook's battery flat on arrival - by p3p1 - 08-28-2017, 03:46 AM
RE: Pinebook's battery flat on arrival - by p3p1 - 08-29-2017, 04:53 AM
RE: Pinebook's battery flat on arrival - by p3p1 - 08-29-2017, 05:17 PM
RE: Pinebook's battery flat on arrival - by p3p1 - 08-30-2017, 04:20 PM
RE: Pinebook's battery flat on arrival - by dejan - 03-19-2018, 08:33 AM
RE: Pinebook's battery flat on arrival - by Luke - 03-19-2018, 09:04 AM
RE: Pinebook's battery flat on arrival - by tllim - 10-30-2019, 07:49 PM
  Dead Pinebook - fix it or spare parts? oloturia 2 2,309 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 1,000 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,360 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 13,110 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 1,028 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,664 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,709 08-18-2021, 11:01 PM
Last Post: Corkonian
  Battery life unrealb2 4 5,733 08-01-2021, 12:26 AM
Last Post: unrealb2
  new pinebook help ron_burgundy 5 7,883 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,851 12-07-2020, 04:02 PM
Last Post: SanjevR
