Armbian 22.02 release announcement
I tried this release and it worked GREAT on the SD card! So I decided to flash it to the eMMC. It flashed fine but failed to boot. I disabled the splash image so I could see what was happening - see attached. It couldn't find the boot device, even though it's there. I'm currently using tow-boot flashed to SPI (also works great). I know it gets to the eMMC (I changed the armbianEnv.txt file to point to /dev/mmcblk2p1 and it complained about that too, so I know it's reading the /boot directory     ).
I used dd to flash the device, and the contents look fine. Same dd command I used for the SD card I've been testing with.
The UUID it says it can't find is the correct one set for the partition. And even though it says it's dropping to the shell, I can't type anything (no, I don't have a serial UART cable). Don't know anything about hardware  initialization process. Anyone have any idea where to look?
Armbian 22.02 release announcement - by TRS-80 - 02-28-2022, 04:55 PM
RE: Armbian 22.02 release announcement - by rleasle - 03-03-2022, 07:47 PM
RE: Armbian 22.02 release announcement - by wdt - 04-06-2022, 03:22 PM
RE: Armbian 22.02 release announcement - by wdt - 04-07-2022, 12:34 PM
RE: Armbian 22.02 release announcement - by wdt - 04-08-2022, 05:06 PM
RE: Armbian 22.02 release announcement - by wdt - 04-09-2022, 11:50 AM
RE: Armbian 22.02 release announcement - by wdt - 04-10-2022, 11:56 AM
RE: Armbian 22.02 release announcement - by wdt - 04-11-2022, 02:04 PM
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,026 12-08-2023, 11:25 PM
  USB 3 port not working with Armbian zaius 3 864 11-13-2023, 01:54 PM
Last Post: zaius
  Audio on Armbian Hobbes42 1 848 08-04-2023, 01:18 AM
Last Post: Humid Stylus
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,503 04-01-2023, 03:22 PM
Last Post: TRS-80
  Sound on Armbian Bram 1 901 04-01-2023, 03:16 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,862 04-01-2023, 02:58 PM
Last Post: TRS-80
  Armbian is [edit: no longer] dropping support for Pinebook Pro TRS-80 4 4,130 12-23-2022, 12:01 AM
Last Post: TRS-80
  Armbian VPU decoding support coming soon LivingLinux 0 804 11-13-2022, 02:32 PM
Last Post: LivingLinux
  Webcam not working in Manjaro with Cheese, but works in Armbian petaramesh 1 1,109 09-30-2022, 10:09 AM
Last Post: crazyquark
  Armbian: Unprompted shutdowns, likely resolved (but weird) mew2020 0 1,310 09-07-2021, 07:05 AM
Last Post: mew2020
