Pinephone Freeze
I thought you were using a pinephone pro. Then the problem is software. I'll try to figure out what could be causing it. It is unlikely that the modem is causing the problem.
Pinephone Freeze - by kmsgli - 02-10-2022, 05:43 PM
RE: Pinephone Freeze - by edgefull - 02-25-2022, 01:46 AM
RE: Pinephone Freeze - by edgefull - 02-25-2022, 03:48 AM
RE: Pinephone Freeze - by kmsgli - 02-27-2022, 07:43 AM
RE: Pinephone Freeze - by edgefull - 02-27-2022, 07:54 AM
RE: Pinephone Freeze - by kmsgli - 02-27-2022, 03:23 PM
RE: Pinephone Freeze - by edgefull - 02-27-2022, 07:42 PM
RE: Pinephone Freeze - by kmsgli - 03-05-2022, 09:15 AM
RE: Pinephone Freeze - by some_pinephone_user - 11-10-2022, 06:20 AM
RE: Pinephone Freeze - by Westslope - 01-23-2023, 08:51 PM
RE: Pinephone Freeze - by zetabeta - 01-24-2023, 08:07 AM
RE: Pinephone Freeze - by Westslope - 02-04-2023, 08:35 PM
RE: Pinephone Freeze - by Kevin Kofler - 01-24-2023, 07:33 AM
RE: Pinephone Freeze - by Kevin Kofler - 01-24-2023, 09:50 AM
RE: Pinephone Freeze - by zetabeta - 01-24-2023, 01:05 PM
  link for supported pinephone os manjharo et all penguins_rule 3 350 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 509 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 1,908 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 2,678 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone craches after each call neithan76 2 1,670 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 30,060 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,158 05-09-2022, 08:29 AM
Last Post: ragreenburg
  "Emergency" terminal on pinephone (with default setup) altulke 5 2,782 05-03-2022, 12:42 PM
Last Post: altulke
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 1,957 04-07-2022, 06:02 AM
Last Post: danimations
  Pinephone stuck on 'something went wrong' after update gofishus 1 1,633 03-06-2022, 05:48 PM
Last Post: fxc
